311 cabin stringers
Does anyone have a drawing or diagram of the stringers from the bulkhead under the cabin door forward? Placement and size is kinda what Im looking for. Im trying to figure out if the carpet that runs up from the cabin floor to where the cushion are is glued to the stringer or just a panel. Cause its soft as hell! Ifs it is the stringer how big wide or thick are they?
probally from the infamous water leak that they all have, (including mine) where water pools up under the step area.
It is glued to the stringer. If they are anything like my 302 they are 3/4" Thick and go from bulkhead to bulkhead.
Originally Posted by theadamv1
(Post 3313058)
Originally Posted by moses0324
(Post 3317848)
mine has the same exact problem...very annoying. i am determined to figure it out this spring. i think it has to do with water coming back into the cabin from the engine compartment when coming off plane. (tube under the cockpit, i am going to try plugging the tube and see if it solves the problem)
Mine does not even have the drain, same with my buddies.
| All times are GMT -5. The time now is 03:08 PM. |
