What prop for a 242LS with a 496HO + Bravo One? >
Old 02-09-2011 | 04:27 AM
Default What prop for a 242LS with a 496HO + Bravo One?
Anyone who has experience with the 242 and props?
Ill think i need a 22-24p prop? 3or 4 blade? Looking for best overall performance..
skidolof is offline
Old 02-09-2011 | 09:46 AM
I would get a Bravo 1 24 if you are close to sea level. You should be able to gain 150-250 RPM if needed by labbing the 24. The 3 blade will give you a faster straight line top speed but I think you will be happier overall with the 4 blade Bravo 1.
Bodi is offline
Old 02-10-2011 | 02:16 AM
Ok, I just bought a 4blade 24p Bravo. Also heard that a Hydromotive 24p 4 blade would be a good choice?!
I think Ill try a Mirage plus 23p to..
The calculated speed of a 23p prop would be 62mph @5000rpm and 15% slip. I dont think the boat will go any faster with a 496HO..
The calculated speed with a 24p would be 65 with same rpms and slip. But i dont think I can make 5000rpm with a 24p?
skidolof is offline
Old 02-10-2011 | 01:24 PM
I don't think you'll ever see 65 MPH (or 62 MPH for that matter) in a 242LS with 425HP regardless of the prop. My guess is best case scenario with that motor is 58-60 MPH. I had a 242LS with a built 620HP motor that would hit 71MPH on a good day spinning a 27P Mirage Plus. Slip is going to be your problem.
The 242 likes a 3-blade prop for top end. I would look at the 23 Mirage Plus or a 25P Mirage (non plus) if you can find one. I think you'll have a hard time spinning a 25 Mirage Plus. If you want better crusing speed, the 22 Bravo One or labbed 24Bravo One. I don't think you'll be able to spin the 24 Bravo One near 5000RPM without labbing it.
I ran a 24P Hydromotive 4 blade on mine and it lifted the stern too much making the boat a handful to drive. The Bravo One would work better in my opinion. I doubt you could spin a 24P Hydromotive 4-blade with that motor anyway.
chewymalone is offline
Old 02-10-2011 | 02:51 PM
my 88 242 ran 59.8 with a stock 365 and 21mirage plus
88242LS is offline
Old 02-10-2011 | 06:53 PM
masi242's Avatar
You are on the right track with the four blade24 if you don`t see the rpms you want you can have it labbed.I will assume the drive ratio is 1.50. My guess is 63gps let us know.
masi242 is offline
