357 Sun Pad replacement Question >
Old 05-16-2011 | 02:03 PM
Default 357 Sun Pad replacement Question
I'm going to replace the vinyl on the sun pad and taking a look at the hatch it looks like I have to physically take the entire hatch off to remove the vinyl as the brackets holding the hatch to the deck need to be removed to gain access to remove the vinyl. Am I correct?
Mach 1 is offline
Old 05-16-2011 | 02:27 PM
yes. it will make life easier. it is heavy. two people minimum to move the cover. good luck. I did mine four years ago.
amazing1 is offline
Old 05-16-2011 | 05:36 PM
SlowPlay's Avatar
just got mine back from upholstery..... good luck!
SlowPlay is offline
Old 05-17-2011 | 06:46 AM
jeff32's Avatar
my sunpad was made out of 3 or 4 different rectangle of wood covered with vynil. so I just unscrewed from underneath the hatch each piece, and it was an easy job!
check it out !
jeff32 is offline
Old 05-17-2011 | 08:28 AM
There are several seperate sections. You can take all of them off while the hatch is still in place on the boat except the last or rear-most section. Some of the screws for that section are under the hatch hinge. So, at that point you'll need to remove the hatch from the boat then remove the hinges from the hatch. Taking off as many sections of vinyl as you can before removing the hatch makes the hatch lighter.
ThirdBird is offline
Old 05-17-2011 | 09:08 AM
Thanks for all the advice. I'm going to tackle that this weekend!
Mach 1 is offline
