-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Replacing steering wheel on '89 292 SR-1 (https://www.offshoreonly.com/forums/formula/255420-replacing-steering-wheel-89-292-sr-1-a.html)
on the edge 06-08-2011 12:28 PM
I just purchased an '89 292 SR-1. Been looking at them for years and finally found a real nice one at a good price. Now I want to replace the gauges, throttles and steering wheel with Livorsi products. Question is whether or not the steering shaft is round and tapered or not? Will it be a simple swap, or will I need something else other than the wheel and hub. Looking at a Momo Spargi. Also, is there enough clearance between the gauges to add a bezel to each gauge? Boat is not near so was hoping for some feedback. Thanks!
Doug
jiffy292 06-08-2011 01:56 PM
Did U Buy A 89 292 From Haverhill/ma /plaistow Nh Area???
jiffy292 06-08-2011 02:00 PM
And Yes You Can Fit Livorsi Guages With Bezels In That Dash Steerring Wheel Should Just Be The Adapter And New Wheel
on the edge 06-08-2011 03:33 PM
Yup! Nice boat! Is that you Courtney? Thanks for the info!
Baja226sport 06-08-2011 04:14 PM
I just did the dash in my 1988 272 and I used all livorsi stuff. Gauges and bezels, steering wheel, and controls.
The gauges will fit without bezels but I wanted to use them so I need to have new dash panels made.
The steering wheel is no problem at all.
The controls required the dash to be cut out to fit them as the livorsi controls are larger than the keikhaefer controls it came with. Needed a new panel to accomodate a trim bezel for the controls as the livorsi bezel is actually wider than the factory dash panel.
on the edge 06-08-2011 05:42 PM
Thanks Baja. Do you have any photos you could post? Also did you get the monster Mega series or just standard size? I plan to make new panels out of carbon fiber, so no problem there.
Baja226sport 06-08-2011 05:51 PM
I could probably email you some pics. I used standard size gauges.
I don't know about your dash but under the tachs and speedo there were 7 factory gauges. Only 6 would fit there with the bezels. that is why I got the new panels. I moved the fuel gauge down to the panel with the ignition switches and bought tachs with built in hour meters.
i had mine made of carbon fiber as well. They look pretty good.
jiffy292 06-09-2011 08:15 AM
Not Courtney But I Know Him Boat With Him, You Got A Great Boat!!
jiffy292 06-09-2011 08:16 AM
Baja---did You Just Use The Livorsi Hub Adapter And It Goes Right On To Formula Helm?? Did It Stick Out Any Further??
Baja226sport 06-09-2011 09:48 AM
I did use a livorsi hub adapter, it looks really nice. Installed with no problems. But yes, it does stick out a little farther than the original. If I have the seat up on my bolster it touches my legs a bit. Not terrible and I am already used to it.
I think they make an adapter that is a little shorter than the one I used. If I did it over again I would look for the shorter one. Tilt steering would help too!
