-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Trim Recommendation (https://www.offshoreonly.com/forums/formula/255982-trim-recommendation.html)
Expensive Date 06-19-2011 02:09 PM
Originally Posted by Audiofn (Post 3432784)
It could just be the wrong props..... Is there anyone in your area that can help you with set up?
Fastechs do that at that speed either drive through it or drop the tabs.They will also do it when you either bring the tabs or trim up too soon after coming on plane.
Audiofn 06-20-2011 09:26 PM
The 312 that I drove had zero hop at all. If your prop has a lot of cup it will have a tendency to give a lot of bow lift. As I think it was you put it earlier in the thread that is probably not a desired result on a step hull. That was why I was saying play around with different props. Props are like magic. Nothing better then a good one and then there are all the rest.... :D
