My new '89 292 SR1! >
My new '89 292 SR1!
My new '89 292 SR1!
Old 06-28-2011 | 08:04 AM
I would go with the Quad IV's again in a heartbeat! With stock 330's I'm getting 63 MPH (GPS) at 4400 rpms, thats 7 percent slip. Midrange is around 43 mph at 3400 rpms. Its taken a bit of time to learn how to drive with them because they need so little trim until your around 54+ mph. With Mirage props I always trimmed right away.
As to your engines, do you know what cams were put in them? I'm in the process of doing something similar with a pair of 365's that I just picked up and I would like to get the 425 hp mark.
endeavour32 is offline
Old 06-28-2011 | 10:41 AM
Put a set of Weiand 177 on them. Change the fuel pump add full roller rockers, run them at 5 psi and I would guess your at 425-440 PSHP.
Then if you want more later, upgrade the exhaust, valves, add a crane #139011 cam and get up around 500PSHP.....
Then add Alum. heads, add intercoolers, more boost 575PSHP?????
Bodi is offline
Old 06-28-2011 | 06:07 PM
Not interested in going the blower route, a simple cam change with better exhaust and I'm at 425. Blowers are a big pain in the a$$ plus they use more fuel than the same HP N/A engine. My last engine in my 242 was putting out 525 hp out of a little 439. It cost some bucks but it was problem free and ran great.
Old 06-28-2011 | 08:16 PM
smart man
88242LS is offline
Old 06-28-2011 | 09:04 PM
motors have comp cams camshafts in them flat tappet also hp 500 heads boat was my friends he has the cam cards also
smokin' gun is offline
Old 06-29-2011 | 08:35 AM
I do have the cam cards at my lake house. I'll get you the info next week.
on the edge is offline
Old 06-29-2011 | 09:06 PM
Old 06-30-2011 | 11:32 AM
nice boat. Looks a-1 shape.
02603sec is offline
