311 Props Questions >
311 Props Questions
311 Props Questions
Old 08-16-2011 | 09:33 PM
I'm getting about 63 (GPS) with my 292 with 330's and Hydo Q IV 24's. I'm curious how the mirages compare!
endeavour32 is offline
Old 08-16-2011 | 10:11 PM
Default prop speeds
89 311 365's Bravo's and gil exhaust. Mirage 25(not plus),3000 rpm cruise , 39mph. WOT 68 mph at 4850 rpm. Bravo 1 26 pitch 4 blades. 3000rpm cruise, 42mph. WOT 67mph at 4700 rpm.
Attached Thumbnails 311 Props Questions-000_0023.jpg   311 Props Questions-000_0047.jpg
bunky1957 is offline
Old 08-18-2011 | 11:35 AM
311 496's 525hp 5100 rpm mirage 25's
pgolder is offline
Old 08-19-2011 | 07:39 AM
Are you running with TRS's or Kaama's? Bravos? Speed?
on the edge is offline
Old 08-19-2011 | 08:28 AM
Originally Posted by Audiofn
I have a 311 with TRS drives. I was at 73 MPH on GPS and trimmed WAY off the indicator. These boats LOVE trim and they go faster and faster the more you trim them, but eventually what you do is chatter the gears in the lower. That is what I did. I don't remember the RPM's off the top of my head. I have another friend with almost the same boat (year newer) and he is seeing the exact same numbers as me.
I'm with ya on the trim thing I think i could use more but my rams are out of travel
Car Biz is offline
Old 08-19-2011 | 08:31 AM
311 454 HP Kamma's 17.5 X 28 5 blades it ran 77.1 @5400
Car Biz is offline
Old 08-19-2011 | 12:55 PM
Jeremy you suck! If it wouldn't cost an arm and a leg I would be looking for something other than the current TRS (Anchors) to push my 311. How's the boat running? Been able to use it much?
TylerBurich is offline
Old 08-19-2011 | 02:36 PM
What up Tyler! I've only ran it 3 times this whole year no time.
Had to replace a fuel pump other than that great!
Car Biz is offline
Old 08-21-2011 | 02:36 AM
311 496's 525hp 5100 rpm mirage 25's labbed with TRS's not real sure of speed at least upper 70's never had it on gps
pgolder is offline
Old 08-21-2011 | 07:20 AM
Audiofn's Avatar
Charter Member #232
The only down side to the TRS with these baots is the lack of room up front when doing a water pump (the nasty azz job I am about to start this AM). Other then that from what I have seen the TRS boats perform better then the bravo ones.
Put your best foot forward!
Audiofn is offline
