Hatch Mirror Grommets
I have read through several threads on here about replacing the grommets for the mirros. Mine have pretty much desintegrated. I went to the hardware stores, Lowes, HD, etc. No one had anything close.
Anyone have 12? Or an online source for the right part? thanks! |
They are the same thing as often used under screws mounting an acrylic windscreen or windshield to the deck if that helps you source some...
otherwise, I have found a similar product in faucet washers believe it or not, in the past when I mirrored my 26 Velocity's hatch there are a million shapes available and many with the "barrel" needed below the big dia. |
Originally Posted by Rippem
(Post 3476280)
otherwise, I have found a similar product in faucet washers believe it or not, in the past when I mirrored my 26 Velocity's hatch there are a million shapes available and many with the "barrel" needed below the big dia. Couldn't find anything even close. Might try scott at formula. |
I found this source online...
http://allstaterubber.thomasnet.com/...ge-plain-bore? I'll have to measure them when I get home. They are "t" shaped right? Or were mine so deteriorated there was no rubber left between the mirror and the hatch? Thanks |
should be "T" I believe but the "barrel" is short.
good find- added that to favorites! |
McMaster.com
I was gonna mention McMaster-Carr...
had never looked for them there, but they have everything else! and because they are in NJ, here in NY I usually get my order the next day standard ship which is nice. |
Yep. Order by 5:00 PM, have them the next day by 10:30 AM. Returns are "no questions asked". I rebuilt most of my boat from the McMaster catalog a few years back.
Thanks guys, should have some next week!
| All times are GMT -5. The time now is 04:49 AM. |
