-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Diamond Plate in 382 (https://www.offshoreonly.com/forums/formula/263330-diamond-plate-382-a.html)
RedDog382 10-02-2011 08:31 PM
3 Attachment(s)
I had my treadplate anodized before I installed it. Just used the same trim piece to hold it in place.
shinglman 10-02-2011 08:37 PM
Thanks,
You just gave me another project I have to do.
Expensive Date 10-02-2011 10:23 PM
Originally Posted by kjm5125 (Post 3518109)
What did you use as "edge material" at the perimeter of the plate? Same stuff that was holding down the gray polyvinyl Diamond Plate?
I did not totaly understand what you meant,till I saw Red-Dogs photos.The 382s are different tahn the 292s I just used the screws that the held the rubber mat down.I left the aluminum perimeter on the wood as it was fine.The piece I cut just dropped in the center.
PhantomChaos 10-02-2011 10:49 PM
Chris......take a look.....there is a motor missing there. Just trying to help out! :) How about a "now" picture to see what it looks like after a few years.....
RedDog382 10-03-2011 11:35 AM
Motor was out to check out an oil temp problem, turned out to be just a sticking oil thermostat.
Unfortunately probably a thick layer of dust collecting on the tread plate now, she's still sitting in my building back in Ohio. Waiting until I get the money to construct a storage building at the house here in Vegas before I bring it out west.
kjm5125 10-04-2011 09:34 AM
Looks good, what gauge?
C_Spray 10-04-2011 03:01 PM
2 Attachment(s)
I got rid of the edging by forming the diamond plate around the wood. I used .090" material, and clear powder-coated it once it was cut and formed. I also narrowed the center section/widened the doors to give better access to the strainers. 4 years later, I've seen no signs of corrosion...
RedDog382 10-04-2011 04:22 PM
Sorry I don't remember and can't find the receit, it was from Tri-state Aluminum on Tracy Road in Oregon, Ohio. 419-666-0100.
RedDog382 10-04-2011 04:24 PM
Nice Chuck! If only you had some access to a professional fabrication shop ... ;)
PhantomChaos 12-05-2011 01:15 PM
Chuck....I think this is what I'm going to do too. Thanks.
