-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   415 hp 502 carb (https://www.offshoreonly.com/forums/formula/264090-415-hp-502-carb.html)
riverrunner242 10-14-2011 09:48 PM
415 hp 502 carb
I have a 1990 242ss I am assembling a 415 hp 502 the motor came with some holley carb on it and a gm aluminum dual plane intake and was wondering, should I run the holley or can i run a quadrajet? My buddy runs 2 415's with quads i was just looking for some other opinions. Thanks for any help
Monaco20 10-15-2011 04:17 PM
Hi I have no idea regarding your carb question sorry,,,,
What is the top speed and crusing speed with the 502???
I have the same boat with 454 330 hp considering an angine upgrade :-)
Regards
from Norway
riverrunner242 10-15-2011 07:57 PM
i bought the boat as a project need some little things so i honestly have no idea i cant wait to get it in the water and find out though. whats your top speed with the 330? What carb do you run on that?
Audiofn 10-16-2011 07:14 AM
Are either carb marine carbs? If not don't run either. I would rather have the holly but if the Q jets is in good shape they do work well and give good fuel economy at cruise. The problem with the Q jets are unless you really know them, and few do, they are hard to adjust and rebuild. If you make any modifications to your motors from stock they will not work real well.
riverrunner242 10-16-2011 10:04 AM
how do you know if its a marine carb? also how do you identify what model holley it is? the motor is a stock 415 and i plan on keeping it that way for at least a few seasons thanks for the help
axapowell 10-16-2011 06:43 PM
The Holley will have turn down tubes from the bowl vents into the venturi's. That's one quick way to tell. The model number will be on the top of the carb on the main body. More then likely a 4150 (double pumper) see if you can get a shot of it and I can help to identify it.
Dave
riverrunner242 10-17-2011 08:50 PM
ok i have the turndown tubes so it is a marine carb it is not a double pumper the number on top of the carb is 6r5533b it also says p-32 on the side of the carb. thanks alot for the help if a shot if the carb will help i will try to post one
axapowell 10-17-2011 09:13 PM
Looks like it is a double pumper by the number. Post a shot of it. It's either an 850 or a Merc 830 CFM. Now, if someone has changed the main body, it could be a custom throw together.
Dave
riverrunner242 10-18-2011 10:19 PM
[img]dsc00145[/img]
riverrunner242 10-18-2011 10:40 PM
http://i1201.photobucket.com/albums/...5/DSC00147.jpghttp://i1201.photobucket.com/albums/...5/DSC00146.jpghttp://i1201.photobucket.com/albums/bb351/shortypantz325/DSC00145.jpg
