How to repair transom after trim tab removal >
Old 12-10-2011 | 06:33 AM
Default How to repair transom after trim tab removal
I recently removed the Bennitt trim tabs from my Formula 292, and plan to install Mercury 280s K-Plates. I now have (4) 3/4" holes thru the transom and (24) small screw holes roughly 1" deep. What would I expect to pay a fiberglass shop to completely fill the holes and refinish the transom to like new condition. OR, is this a fairly simple task that I could handle myself?? Any help would be appreciated...thanks.........dave
rocket ride is offline
Old 12-10-2011 | 06:59 AM
Talking
You'll need more than new tabs to get 70 out of that thing!
JC
hemihead is offline
Old 12-10-2011 | 08:37 AM
P.M. sent
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-11-2011 | 05:47 AM
[QUOTE=hemihead;3568291]You'll need more than new tabs to get 70 out of that thing.
Funny......boat already does 70+, I'm just lookin' for stability beyond what Bennitt tabs offer.
Old 12-11-2011 | 05:48 AM
Originally Posted by RunninHotRacing163.1
P.M. sent
Thanks for the advice RHR163....check out my PM....dave
Old 12-11-2011 | 09:01 AM
It is a fairly easy repair if you know anything about auto body repairs. Can you spray gelcoat? Buy a pint of gel from Formula so the color will match. I think I paid around $30 for a pint from my dealer. Once you get the gel I can walk you through the repairs. The 280 tabs will cover almost all the small holes, so they just need to be filled and no gelcoat applied. If you have the 2003 Powerboat magazine article on installing 280 tabs on a Fastech it makes the complete job much easier. Jeff Wurl
jwurl is offline
Old 12-11-2011 | 09:26 AM
Thanks for the support Jwurl!! I received some help in a PM from another member.......see attached
get yourself some dowel rods and some West systems 105 resin & 207 slow hardner and run the drill back thru the holes to clean them up and coat the hole with the west systems and the dowel rods also and tap them in so there 3/16 below surfaces on both sides of transom so you can cover with a layer of gel coat ..its a very easy job
Does this sound like what you did, I think I remember your post from last year, but can't find it. I know there is a post on OSO detailing the project.
Once again, thanks for the help.........dave
Old 12-11-2011 | 09:27 AM
got it dave ,any ???? feel free to call
Old 12-11-2011 | 10:58 AM
I am getting ready to do the same swap. Looking for templates, wiring and plumbing diagrams and hole fill ideas. I have used marine-tex in the past. I may even go Horozontal with my tabs.
AZ Lineman is offline
