Towing 382 >
Towing 382
Towing 382
Old 01-18-2012 | 06:37 AM
SS930's Avatar
What does a typical 382 weigh? Is it on a steel or aluminum trailer?
To answer your question, as long as your trailer has decent brakes you should be fine with a decent 2500, especially if you're only traveling 10 miles.
SS930 is offline
Old 01-18-2012 | 06:54 AM
t500hps's Avatar
21 and 42 footers
Originally Posted by boatnt
you are correct you can not put a Allison in a Suburban...
but you cant put a Allison in a G Van either and GM offers the 2500 G van with a Duramax and a 4L80E...you dont need a Allison to be a 3/4 ton truck..
The 2500 HD pick up is not rated for 15.000lb..
been a GM Master tech at the same Chevy Dealer for 26 years.. the 2500 Chevy Suburban is a true 3/4 truck
didn't know that about the vans.
With all the side to side sway, it seemed like the tail wagging the dog when I hauled the 382 with it.......bought a dually just 6 weeks later.
t500hps is offline
Old 01-18-2012 | 06:56 AM
t500hps's Avatar
21 and 42 footers
factory weight is 10,500, add 1,500 for an aluminum trailer (2,500 for a steel), gear, up to 200 gallons fuel, you could be hauling 15,000 if loaded.
I had my trailer built with 13in disc brakes on all 3 axles, the rig would stop in a shorter distance with the boat than without.
t500hps is offline
Old 01-18-2012 | 07:00 AM
SS930's Avatar
I think you might have just taked me into upgrading my trailer brakes to the same rather than fixing my surge/drums.
SS930 is offline
Old 01-18-2012 | 07:56 AM
t500hps's Avatar
21 and 42 footers
You should!!!
I've been towing with a PSD dually. That 382 rig had S.S. brakes but it was surge, still worked great though. I now have a 21ft center console with brakes on one (of two) axles. The total rig only weighs about 4,000 yet it takes a longer distance to stop than the 382 did.
t500hps is offline
Old 01-18-2012 | 08:30 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There is no better setup than an EoH system pushing on disc brakes; Kodiak discs at that.
I wouldn't tow a 382 with less than a dually, but that's me. Do some searches on the DRW vs. SRW threads.
Sydwayz is offline
Old 01-18-2012 | 08:54 AM
SS930's Avatar
Yeah, they've been beat to death! The long and the short of it is a DRW will be a little more stable but a SRW 2500 like the OP is inquiring about will certainly handle the task he's outlined.
Yet this thread will turn into the typical DWR/SRW thread even though the OP isn't asking about DRW trucks.
SS930 is offline
Old 01-18-2012 | 08:55 AM
SS930's Avatar
You should!!!
Thanks for the feedback!
SS930 is offline
Old 01-18-2012 | 10:20 AM
i'm still baffled as to how you pull your rig with the diesel ram 2500 especially with a steel trailer, big blower motors, and #6 drives. what do you figure everything weighs?
1MOSES1 is offline
Old 01-18-2012 | 10:26 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Depends on the capacity of the truck; and if you want to tow legally.
Old topic--new thread.
That boat/setup has to be over 14K lbs. loaded, then fuel, water, beer, coolers, tools, parts, etc. etc.
Sydwayz is offline
