-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fastech LED Cockpit Lights (https://www.offshoreonly.com/forums/formula/269051-fastech-led-cockpit-lights.html)
sleek1 01-19-2012 10:33 AM
I've wanted to change over my cockpit lighting to LED (probably blue) for some time. I'm sure some of you have done it, I've looked at various brands. How difficult is it? Do I need to add balasts or some kind of module or is it as simple as cut wires, mount lights and rewire?
laketravis 01-19-2012 03:38 PM
Killer LED Lighting
I have some ideas!
Splitdecision271 01-19-2012 05:59 PM
You do have options.
1. The cheaper and easier option is that you can simply replace the bulbs in the existing lights with LED's. Check out superbrightleds.com. It's as simple as pull the old bulb out and put the new bulb in. All for under $50. What you'll need are:
(2) Miniture Wedge Base Bulbs (For lights up front at floor level)
(3) 1142 Dual Contact BA15 Base Bulbs (2 for the side compartments, 1 for up under the dash.)
2. The more expensive and time consuming option would be to search the internet for a complete replacement LED light and housing. Which you'll have to redo your wiring and heat shrink to waterproof your connections. You might also have to drill a larger hole to accomodate the new light housing.
bonesmalon 01-19-2012 06:12 PM
Check out how cool they look 37 Active Thunder
https://picasaweb.google.com/1159749.../ActiveThunder
C_Spray 01-19-2012 09:38 PM
4 Attachment(s)
(3) 1142 Dual Contact BA15 Base Bulbs (2 for the side compartments, 1 for up under the dash.)...
Bingo. Cheap, quick, good results. Before and after:
Therapy Session 01-20-2012 01:06 AM
http://www.youtube.com/watch?v=Gm8h9hLqPjs
If you want to go overboard here is a link to what I did. Put RGB million color led's in all the speakers, cup holders, back engine vents and under bench seats. Control it all with a remote. Can do any color you want. Set any color combo you want. Has music interface as well. Used acrylic rings behind all the speakers and cup holders. I think it turned out pretty cool.
sleek1 01-20-2012 10:29 AM
I think this is the ticket for me. I'm looking for something more sedate than the other set ups. Thanks for all the pics and videos. Therapy Session your set up is wild! Good job on the install. I would get into trouble with my wife if I had a light show like that on my boat... thinking strippers, lots of strippers:drink:
sleek1 01-20-2012 10:38 AM
Anyone have a part number for the miniature wedge base bulbs?
TN Formula 01-20-2012 01:05 PM
led wholesalers is another option. most of mine came from superbright but the few i couldn't find i got from them.
Therapy Session 01-20-2012 06:56 PM
Yes you are correct. The women do gravitate to the music and lights:evilb:
