hull issue on 87 242 >
Old 01-27-2012 | 12:36 PM
Default hull issue on 87 242
I picked up my first boat last fall. Its an 87 242 ls 330hp alpha. I love the boat and have been vary happy with it but have found something that needs to be addressed. On the port side in about the middle there is ruffly a 2 - 3ft section where the hull meets the top under the rub rail it seams to have come unbonded. If i push on the side it bows in away from the rub rail about a half an inch or so. It looks like there are screws that go threw the rub rail into it but have been pulled out. I did some research and it looks like the tops were glued on. My question is, how serious of a problem is this and what would be the best way to go about repairing it? Thanks in advance for any and all input it will be much appreciated.
[IMG][/IMG]
bwhicker649 is offline
Old 01-27-2012 | 02:09 PM
boat looks great love the 242's
88242LS is offline
Old 01-27-2012 | 06:47 PM
Thanks a bunch. It took a lot of tlc to get it back to that shape but all in all I am amazed at how well it has held up over the passed 24yrs but thats a formula for ya!
Old 01-27-2012 | 10:43 PM
I have seen this on a few Sea Rays...but not a Formula.
I had this situation on a 40' Sea Ray EC. I removed the rub rail and put in new stainless screws in new locations offset from the original. Before I tightened the screws down I ran a bead of 3M 5200 in the gap. I then ran the screws down tight and wiped off the excess 5200. After I was satisfied with the result I re-attached the rub rail. Make sure you remove the excess 5200 quickly because once it dries ...you need a stick of dynamite to get it off!!
This made a bond that was stronger than the original for sure.
This is a minor repair that you need to address...it could develop into some stress cracks or spider webs later. That area is especially vulnerable to damage if you bump a piling hard enough while docking.
Do it now while it's not a big deal.
Love your boat...hanging in there for a 25 year old!!
sprink58 is offline
Old 01-28-2012 | 07:44 AM
See thread above
fossil fuel is offline
Old 01-28-2012 | 09:37 AM
Do what Sprink said but also use some backing plates on the screws that are under the rub rail. This with make it very secure and it will not happen again! I think the screws should be around a 1/4" pan head if I remember right.
endeavour32 is offline
Old 01-28-2012 | 07:18 PM
After seeing this- I went in the garage to see my new to me 311 sr1 and the bond is gone on about 1/2 of the boat !!! It's an 89 but wonder how long this has been an issue. Guess I have my work cut out for me come spring
oldscoolscarab is offline
Old 01-28-2012 | 11:33 PM
Same exact boat as mine minus the ugly side hull windows and you have the rounded windshield!! nice boat!
86242ls is offline
Old 01-29-2012 | 11:53 AM
Removing rub rail and securing the upper deck to hull with 5200 is a good start. But when installing the screws thru the upper deck and hull sides use stainless bolts and nuts with backing plates. Then when installing the rub rail I installed 10 foot 1/8 thick strips drilled to match rub rails.
I was amazed on how much difference I felt in rough water. Fewer shakes and rattles and an over-all more solid feel to the boat.
OPIE272 is offline
Old 01-29-2012 | 11:09 PM
PhantomChaos's Avatar
Originally Posted by OPIE272
Removing rub rail and securing the upper deck to hull with 5200 is a good start...........
There is talk about using 5200 on the hull/deck bond in this thread. It's not recommended. Look around post 150-ish
http://www.offshoreonly.com/forums/f...ml#post3326384
PhantomChaos is offline
