Upright posts docking question >
Old 01-31-2012 | 02:16 PM
Boomer35: Thanks for the explanation, now it makes sense! You're right, every type of docking has pros and cons. I think I'll be able to work around the posts next time I return.
Yes, that's true about the no wake zones so that there shouldn't be a problem with a lot of bouncing around. That was our first experience in boating at Lake George and I have to say the Lake is absolutely beautiful! You have to really miss boating there, especially after living there so long.
Hematite is offline
Old 01-31-2012 | 02:19 PM
Originally Posted by C_Spray
That looks like the best way, but hanging your fenders from your boat horizontally as Sydwayz suggested works just fine, too. We hange them horizontally for raftups as well.
You guys are right, the horizontal fenders will definitely help. I saw one boat that was taking no chances and had large fenders at the waterline tied to the dock and the Taylor post bumpers there too!
Hematite is offline
Old 01-31-2012 | 02:20 PM
Originally Posted by Downtown42
Spring lines each way will help hold your position as well.
Yup, also going to order spring lines!
Hematite is offline
Old 01-31-2012 | 06:06 PM
Originally Posted by Hematite
These might work, I wonder if anyone has experience with this setup. A bit of a PITA to set up as compared to fenders which are easier to deploy but they might work.
http://www.amazon.com/Taylor-Product...ef=pd_sim_sg_1
If they saved the Imron they would be worth it.
I have been using these on Lake George for years. They work great. Funny thing is I've never seen another boat on the lake that has them.
They are easier to use than horizontal fenders.
lg260ss is offline
Old 01-31-2012 | 07:56 PM
Great, that's good to know! That's what I was leaning towards since they cover the upright post. Since you also have a 260SS, I know they will work with my boat, too. You probably only need 2 to do the job, I would think.
Hematite is offline
Old 01-31-2012 | 11:52 PM
That's exactly what I use too. We have the exact same dock setup. I'm the only guy around here that has them, and everyone always asks where I got them. They work great. I often tie off fenders horizontally too, just because I'm a bit anal.
RT930turbo is offline
Old 02-01-2012 | 08:53 AM
I throw my small stearn anchor out before I dock then tie it off the center cleats, helps keep boat off the dock
oh6662b is offline
Old 02-01-2012 | 09:16 AM
Yes I use 2 of them. I have had the same pair for over 10 years and 3 different boats. I also camp on the islands often and some of those docks get really rough. My Imron is still perfect after 5 seasons.
I do hang an 8" diameter fender on the stern cleat if its real rough. It holds the stern away from the dock. I will try to find a picture to post.
lg260ss is offline
Old 02-01-2012 | 10:40 AM
Now that's also an excellent idea especially for the island camping docks. As lg260ss said they get really rough and the anchor would help stabilize the boat. Never thought about using the anchor that way.
Hematite is offline
Old 02-01-2012 | 12:33 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
We are all used to tying across a single boat slip to suspend the boat without using fenders. You can do the same with 2 boats in a bigger slip. It keeps the boats from banging the dock, and usually keeps some idiot from trying to squeeze between the two boats.
Sydwayz is offline
