Drive trim and bumpstops >
Old 04-10-2012 | 10:21 AM
Default Drive trim and bumpstops
Apparently Formula installs bumpstops in the drive trim cylinders to prevent lower units from hitting the silent thunder box if equipped. My shop found that these pieces had deteriorated and broken apart on my 292. The debris in the trim cylinders was preventing my drives from full trim in either direction.
Just wanted to pass along and curious if anyone else has run into this issue.
diverkr is offline
Old 04-10-2012 | 11:14 AM
C_Spray's Avatar
Diamond Member #001
I beleive that Formula also does this on trim tabs for some models. What material were the stops made from?
C_Spray is offline
Old 04-10-2012 | 11:20 AM
Not sure haven't seen it yet. I think some kind of plastic. BTW my ST box has been removed.
diverkr is offline
