292 Fastech/Scorpion Exhaust Options >
Old 05-03-2012 | 08:34 AM
Default 292 Fastech/Scorpion Exhaust Options
Well, the Silent Thunder is off and now I'm thinking I want to continue to shed weight. I know a couple of you have gone with Stainless Marine for your 350's and 6.2's. But what should I get for the blue 377 Racing Scorpions? Just the replacement manifolds and use my stock pipes or do I need the High Torque Standard Exhaust System? Do I go long on the HP riser kit? I know the vendor can answer most of this but there is nothing more valuable than the advice from the field...what do you all recommend? I have considered the CMI's but I think at double the price, not really worth it and I here there can be trouble dialing in the water and exhaust ratio. There is also the Imco Powerflow S-Pipe, but I hear less if anything about them?
pondrunner is offline
Old 05-03-2012 | 09:29 PM
Expensive Date's Avatar
Stainless Marine, I would call them to get exact information. I went with IMCO and while I am happy with them as all there products I feel Stainless Marine will be better for your engines. Headers are a wast of money on a small block and when they leak they will take out an engine.
You will love how much better the boat planes / rides with a couple of hundred pounds off the rear.
Expensive Date is offline
Old 05-04-2012 | 06:08 AM
Did you go Thumper with your pipes or Powerflow with their pipes?
Old 05-04-2012 | 07:00 AM
Thumper, was just replacing stock that was bad.
