Engine just stopped >
Engine just stopped
Engine just stopped
Old 05-22-2012 | 04:00 PM
Default Engine just stopped
Starboard engine on my 382 stopped after running fine all day with no warning. No alarm and no faults show up on the screen. She'll turn over and run for a few seconds and quit. I changed the fuel filter but it didn't help. 75 hrs on both engines, port still runs fine. Any thoughts? Fuel pump? Is there a reliable tech on the Del-Mar-Va peninsula?
whistler is offline
Old 05-22-2012 | 08:27 PM
How does the starboard engine run for those few seconds before cutting out. Is it rough, smooth, a little of both?
Splitdecision271 is offline
Old 05-23-2012 | 05:47 AM
moparjet's Avatar
My buddies 312 did the same thing.. blew fuse for fuel pump.. found wire shorting in the e-box..
moparjet is offline
Old 05-23-2012 | 05:54 AM
A little of both
whistler is offline
Old 05-23-2012 | 06:03 AM
What engines do you have?
teamsynergy is offline
Old 05-23-2012 | 06:19 AM
The 600's
whistler is offline
Old 05-23-2012 | 09:22 AM
Which filter did you change? The spin on (#31) or the inline (#40) I would if you just did the spin on, the inline might be the culprit with some blockage.
Old 05-23-2012 | 02:20 PM
Spin on, I'll look for the in-line next and check on those fuses as well
whistler is offline
Old 05-29-2012 | 09:00 PM
Check the IAC sensors/motors. They have a tendency to burn up which won't allow the boat to idle properly.
I've also read something recently about the mechanic fuel pumps. The older pumps can build up pressure in them and cause issues. Newer ones apparently have a pressure release valve on them.
Last resort, sometimes the first, contact Merc Racing. I'm sure they'll be willing to help.
