Suggestions For Riding In Rough Water Please! >
Old 06-11-2012 | 12:47 PM
Originally Posted by pondrunner
As has been said...I'd take open ocean broads with evenly spaced rollers any day over lake slop. Unpredictable and constantly changing with very tight spacing. The small fastechs (271,292,312) seem to NOT want to run slow. At 3000 rpm they are very azz heavy and tend to porpoise without the tabs full down. 3500 seems to be a much better ride and cruise speed, shifts the cg and levels out the bow. Contrary to a regular deep vee, I find that I'm not using as much tab in the rough and I actually use just a touch of negative trim with the drives. This is exactly what powerboat magazine said was the best way to counteract rough water with the 292. They mention nothing about tabbing deeper. I think if you tab/plane too deep with the fastech hull, it lifts the azz and helps nothing in the rough. Try allowing the hull to do the work and just tuck the drive in from neutral slightly. I've got to think the 312, 1000 pounds heavier would be a decent ride...I'm fine with the 292 on lake Ontario!
My 292 was the same way with the Bennett's. Those tabs were too small to hold a slow plane, the azz would sink and it would porpoise. Not so with the 280S K-Planes! It will hold a slow plane (30-32mph) and ride real nice and smooth plowing through some really nasty slop.
Although, when running solo or with willing passengers, letting her fly is definitely a more fun option!
4mulafastech is offline
Old 06-11-2012 | 01:25 PM
Every Formula Ive ever owned wanted power when it got rough, 242- current 303 gets bouncy power up and chop it up,
88242LS is offline
Old 06-11-2012 | 07:24 PM
Mine likes it faster too. Slow down and you can get a pound or two but nothing like what I have grown up with. Get some air under the step and let the engines eat some fuel.
looseconnection is offline
Old 06-12-2012 | 05:33 AM
Audiofn's Avatar
Charter Member #232
Originally Posted by sprink58
OK...being a 4 time Formula owner and having taken all 4 of those boats into some very rough "OPEN OCEAN" conditions...I'm have a little trouble understanding a 312 Formula FasTech experiencing "rough" conditions on an inland lake. Considering that the LOTO is about 90 miles long, has an average depth of 60~80 feet and has no significant depth fluctuation...I wonder...how rough could it be? Are we talking 3'~5'...or as much as 4'~6'?
Enjoy this 312 video!!
http://www.youtube.com/watch?v=sU7brK843oQ
Find a comfortable trim and speed...drop the bolsters...throttle up and get on top of that slop and let the hull do the rest
LOTO is nasty... real nasty. I would run the drives more or less nutral (you will have to make small adjustments depending on your props, people on board...) and adjust the tabs for best results.
Put your best foot forward!
Audiofn is offline
Old 06-12-2012 | 06:36 AM
Never been there...look forward to it some day....so I can't speak to it's roughness. Seems a bit odd though with a depth of 60+ feet and covering as much area as it does that it would be that rough.
About the roughest thing we see here inside is Biscayne Bay south of Miami. It's about 1/4 the size of LOTO but is only 12'~15' deep in the center of the bay. When the wind whips up it gets a washing machine going due to the shallow depths.
But then again...there is the "ditch" or ICW in Broward Co between Ft. Lauderdale and Boca. It's 12' deep and 100 yards wide and on the weekends it's a friggin' cauldron.
sprink58 is offline
Old 06-12-2012 | 08:48 AM
I've been on a few smaller lakes but LOTO is a whole beast in itself. Weekends can get downright impossible to drive in. Massive 40-45 foot cruisers putting out 3-5 foot waves in every which direction...I would compare it to driving in a blender. No discernible wave pattern with waves coming in all directions. It can be very pleasant during the week but if u are out on the weekends hold on.
LOTO on a weekend=a very challenging drive to master...unless u have a 38+ footer that will just plow through wave after wave.
A big thanks to everyone who has replied with advice, it is really appreciated.
paaka937 is offline
Old 06-12-2012 | 10:48 AM
Knot 4 Me's Avatar
All boats are different but I would start with tabs and drives neutral when it gets rough and experiment from there. It may like a hint of negative tab and drives neutral to slightly positive or the tabs neutral and the drives neutral to slightly negative. Try to get up on top of the water as opposed to plowing through it. Look to keep the nose down but not so much that it is wanting to bow steer.
Knot 4 Me is offline
Old 06-12-2012 | 04:19 PM
Audiofn's Avatar
Charter Member #232
When you think of LOTO think of as others have said large cruisers, not so large cruisers, speed boats, jet ski's... all going in different directions. Then think of your pool and a lot of people all jumping into it at one time. When the waves from all those people hit the walls they all come back to the middle making much larger rogue waves. Loto's walls are strait up so all the waves go back to the middle. You can be running well in 3 footers then all of the sudden the bottom will drop out and you fall 3-4 feet. It is insane really. I did not appreciate it tell I was there. Makes for some testing of your driving skills.
Audiofn is offline
Old 06-13-2012 | 08:46 AM
Full Force's Avatar
Run the boat at 45 I bet it's way better.... Lake Erie probably has the worst chop washing machine water of any lake I know... 5 foot high.... 5 ft apart... you gotta get the boat up out of water to make it run smoother... lots of practice helps...
Full Force is offline
Old 06-13-2012 | 09:34 AM
Mentalpause's Avatar
Best luck I've had at LOTO on a sloppy day is to run the aft tip of the K plane almost even with the bottom of the boat, measuring by running a straight edge parallel out from the bottom of the boat and lower the K planes until they touch the straight edge. I mark that position on my gauge. Then put the drives in pretty much a neutral position. If you run the drives and K planes in a negative position I suspect you are diving the nose hard into the troughs instead of riding over them. If you start from those setting you can tweak either drives or planes to see how the boat reacts.
The other thing is the knack and timing of throttling, which just needs hours of practice. The major mistake many people make is to back off the throttle when they hit a nasty patch of water. That take all the thrust away from your props and lets the water push the boat around. Within reason you should do just the opposite, throttle into the rough and out as it quiets down. If you see a nasty patch of water ahead of you try slowing before you get to it, then throttle into the patch just as you hit it.
Mentalpause is offline
