fuel pick up access? >
Old 07-28-2012 | 05:21 PM
Default fuel pick up access?
Any one know where the fuel pick up access is in a 1998 271 fastec? i found the fuel gauge sending unit under a access cover under the rear seat.
cstobe is offline
Old 07-28-2012 | 10:06 PM
Default fixx
if you cant see it through the access plug then you have to remove the bolsters and the center part of the floor to get at it..
FIXX is offline
Old 07-30-2012 | 08:16 PM
Thanks for the reply. It does sit right on the edge of the access hole. Had to contort to just the right angle to see it.
cstobe is offline
