Formula Brochures and Performance Results >
Old 08-27-2012 | 08:58 PM
Thanks for posting the 292 data!
endeavour32 is offline
Old 08-28-2012 | 01:39 AM
Originally Posted by Mr Maine
Yeah, wasen't sure when the 320 EFI came out (87 or 88), I knew they had a carb version called the tempest previous to the EFI and was rated at 300 horse.
At anyrate, yeah that motor pushes that boat really well and the hull takes it no problem. I run consistently at 63gps and have seen 66 with a little tale wind.
Now I just have to build 2 of them and throw them in a 272 and I'll be pretty set for where I want to be!!!
The 320 EFI was available as a special order in '86...I had twin 320 EFI's in a '86 272 LS with Alpha SS drives. Built in the Miami Plant summer of '86. The boat ran 75 speedo with 23" cleavers at 5800~6000 RPM. it would run an easy 60 at 4500.
sprink58 is offline
Old 08-29-2012 | 08:33 PM
axapowell's Avatar
Where To
Originally Posted by 88242LS
Cool info, anyone got anything concerning the 303?
I think I still have the 1993 303 book. I'll check.
Dave
axapowell is offline
Old 08-29-2012 | 09:48 PM
Dave
awesome, thanks
88242LS is offline
Old 08-29-2012 | 10:11 PM
Dtile's Avatar
thanks
Dtile is offline
Old 09-05-2012 | 09:29 AM
Originally Posted by 88242ls
cool info, anyone got anything concerning the 303?
As requested, datasheet on the 303.
Soflow1 is offline
Old 09-05-2012 | 03:00 PM
Attachment 481746
Thank you,
88242LS is offline
Old 09-13-2012 | 09:42 AM
Default MPG difference
OK, this strikes me as odd. The 311 sheet and the 303 sheet are both Sr1's and both have twin 454 mags bravo's (365hp).
The 311 is 3" narrower but 150 lbs heavier and 2' 9" longer with the swim platform.
I would have thought the 303 would have gotten better "milage", but the numbers posted by formula do not show that. Best for the 311 is 2.1 mpg at 28 mph at 2500 rpm. The 303 was only 1.7 mpg.
The 311 was faster and more fuel efficient than a boat almost 3' shorter? Did they just screw that boat up?
befu is offline
Old 09-13-2012 | 09:44 AM
Originally Posted by JTeam
Here is the 292 page per endeavour32's request
You wouldn't happen to have one for the 272 would you?
Brian
befu is offline
Old 09-13-2012 | 01:10 PM
Brian i think the hull design might have something to do with it. i think the 311 is more concave than the 303.
Car Biz is offline
