Thru-Transom Water Pickup - 242LS >
Old 08-13-2012 | 01:07 PM
TomZ's Avatar
Default Thru-Transom Water Pickup - 242LS
My 242 overheats. Finally got into everything (pump, hoses, etc) and found that the transom inlet is the issue. So I need to install a thru-transom pickup plus flush inlet. Fun.
I ordered a cut-to-fit pickup from Eddie Marine (should be here tomorrow or Wednesday). My question... where to put it exactly? I'm thinking inboard of the engine stringer on the starboard half, aiming for halfway point between centerline and strake. Good?
Any thoughts?
On another note... Found some rot in the boat. Looks like a winter overhaul is in order.
Tom
TomZ is offline
Old 08-13-2012 | 01:51 PM
Any thoughts?
Tom
I can send you pictures of my Teague transom pick ups if you would like.
PM me if you want them.
Thanks.
Made It Rain is offline
Old 08-14-2012 | 07:07 AM
whats wrong? collapsing hose? replace it no need for another hole in the boat
88242LS is offline
Old 08-14-2012 | 07:23 AM
TomZ's Avatar
Corrosion in the transom assembly.
TomZ is offline
Old 08-14-2012 | 06:09 PM
masi242's Avatar
I had been fighting a overheating problem problem also, the plastic hard plastic hose that comes thru the transom was cracked and had debris caught up in it. It sure is nice not to see that temp gauge go up. My 242ls has the 454/alpha.
masi242 is offline
Old 08-14-2012 | 09:02 PM
aquaforce's Avatar
I wish I didn't know anything about that over heating cause but I do. Once that corrosion gets between the tube fitting and the transom housing it just corrodes until it collapses and restricts the feed hose. That happened on my 89 242LS. Problem was that the corrosion ate through the transom housing and wicked into the transom. I have to replace both now.
Good luck with your project.
aquaforce is offline
Old 08-16-2012 | 12:32 PM
TomZ's Avatar
That sucks!!
I'm not quite in that situation, but just as bad. I'm going to be fighting stringers, bulkhead, and possibly the transom over the off-season. Call me crazy but I'm actually looking forward to the project. For now, I'll be fixing the overheat issue, and using her gently for the remainder of the season.
Good luck with yours!
Tom
TomZ is offline
