382 Fastech Hull / deck joint repair >
Old 11-09-2012 | 11:21 AM
CS, I should have it ready within a week as long as we don't get jammed up at work.
I spoke to Scott at Formula also about the Plexus & mixing gun loaner, so that would probably work out great instead of shipping the gun back & forth to Fomula.
I'll give you a call over the weekend,
Don
katywompus is offline
Old 11-09-2012 | 11:58 AM
KW- the screws tap into a 2"x2" 1/8" aluminum backing plate. You can see these plates when you get the cabin speaker valances down. Also have Formula check the date codes on the Plex before they ship. It will save you a return and reship.
fossil fuel is offline
Old 11-10-2012 | 01:29 AM
PhantomChaos's Avatar
Why...........are they using out of date material?
PhantomChaos is offline
Old 11-10-2012 | 08:39 AM
They use the product in bulk drums for production. The hand gun tubes sit on the shelf for repairs and go out of date.
Old 11-21-2012 | 06:45 PM
Got it....thanks!
Old 05-24-2013 | 08:10 AM
Just an update to those that were following this:
Finished up the repair back in February, was quite a bit more of a job than I anticipated. The joint was loose for pretty much the entire boat except the front & rear maybe 2 or 3 feet, but this popped loose while I was spreading the joint to grind out the old material. Once loose & all the screws were out, the rear of the deck ( around the engine bay ) dropped approx. 1/2" which required hoisting the rear of the deck up by the cleats with a forklift to line everything up for re-assembly. But everything is good & tight now! Hope to be back on the water in a week or so.
Also replaced the headliner over the winter & rebuilt/ updated motors last fall. Trying to get all the major stuff out of the way.
