Raise the X or Not?
Cost was the major factor. I'm on a tight budget with new transom and paint job. I'm looking at spending 9k within the next month and was thinking I could save a little with raising the motor.
I would leave it alone and find a used lower shortie. I had a -1 on my 271 fastech for a while and the boat was very unsafe bad chine walking. If you do all that work and it's not what you like or does not handle well then your stuck. If you do the lower you can always take it off if its not right....just a thought
Quote" would leave it alone and find a used lower shortie. I had a -1 on my 271 fastech for a while and the boat was very unsafe bad chine walking. If you do all that work and it's not what you like or does not handle well then your stuck. If you do the lower you can always take it off if its not right....just a thought"
To clarify you attributed raising the drive to the chine walking?
The reason I'm asking is just helped a friend decide on the purchase of a -1 Imco for his 271 and we thought it may help with handling issues to get the drive up out of the water a bit.
Was that the only change you made, adding the -1 and it started chine walking afterwards?
Did trim tabs help, and where were they mounted on your hull?
We moved K-planes on a Checkmate down V to center about halfwasy from outside and it helped with stability.
I agree 353 these are two different boats. I'm going to take everyone's advice and keep the X the same and just go with a shorty. These boats are nose heavy and need the motor lower to keep the nose positive and not run flat. I'll keep you posted the wood is going back in this week and the hole is going to be cut by the 2nd.
What was the original depth? If it was 7 or more inches below the hull and I was cutting a new hole anyway, I would raise it. Spacing down is cheap and if the new height works, it costs you nothing. If it works and you are still curious, you still got another 1/2"- 2" left that you can go up with different combinations of a shorty lower and spacers.
