New to offshore >
New to offshore
New to offshore
Old 04-09-2013 | 11:42 AM
  #111
Has anyone ever installed a Hummingbird 597ci HD combo depth finder, sonar and GPS unit in a Formula? I'm about to start installing on and looking for helpful hints!!
84 Formula 272 is offline
Old 04-09-2013 | 11:52 AM
  #112
I have an hds 5 which is a great combo unit. Was easy to install. Only had to run ducer cable from engine bay up to dash and reconfigure dash panel which I had all new gauges anyway.
Crude Intentions is offline
Old 04-09-2013 | 11:54 AM
  #113
Another. Countersunk
Old 04-09-2013 | 11:55 AM
  #114
Next wanna add these
Old 04-09-2013 | 11:57 AM
  #115
That looks really good!!!! Any problems with shooting through the hull?
Old 04-09-2013 | 12:03 PM
  #116
Mine is transom mount right now. Panel still needs paint and hydro dipping. All panels are being redone. Commandersander did the work on the panel. Great guy.
Thinking I might pull the motors next "winter" if you call it that in south Florida and redo the transom. Has 2 soft spots in upper right corners. When it is redone I may switch to thru hull ducer
Old 04-09-2013 | 12:09 PM
  #117
Ya I'm back and forth on transom mount or shoot thru hull!! I have heard it works alot better transom mount!!
Old 04-09-2013 | 12:12 PM
  #118
We've had transom mount on all our boats and no problems. One extra hole in transom above waterline below platform. Seal it and no problems.
Old 04-09-2013 | 12:16 PM
  #119
Does the second motor affect the placement on transom?
Old 04-09-2013 | 12:17 PM
  #120
No. Mine is between drives down low on the v.
