f302 setup and speeds? just purchased! >
Old 02-22-2013, 10:58 PM
Cool boat
Crude Intentions is offline
Old 02-22-2013, 11:05 PM
Thanks. Thrilled to have a formula. let the spending begin.....
deepv29 is offline
Old 02-22-2013, 11:35 PM
No doubt. I've been spending non stop since I bought mine a year ago. The breaks of buying an older boat and having aspirations of upgrades. Lol. I love the boat though. Great ride and roomy for the family.
Old 02-23-2013, 09:48 PM
Don't get messed up in the head about the money...consider it "Sanity Maintenance".
sprink58 is offline
Old 02-23-2013, 09:53 PM
My 302 has 330's changed over to center dump manifolds and refreshed everything with 3 blade 23 pitch mirages does 62 top end at 47-4800 rpm
welfare racing is offline
Old 02-23-2013, 10:30 PM
I figured it pretty close...LOL How big of a job was it to swap to center dump? I was amazed at the weight difference between them and the old Log type exhaust. I would not be surprised to know that changing them saves 250+ pounds on your boat.
sprink58 is offline
Old 02-23-2013, 11:39 PM
Charter Member #232
Audiofn's Avatar
I would not go with 4 blades. 4 blades and TRS drives is a no no. They will cause the drive to blow up. Second the drives are very deep so the extra blade is a lot of drag and more then likely make you slower. Mirage props seem to work best on them. You want smaller diameter props when you are deep in the water like TRS drives are.
Put your best foot forward!
Audiofn is offline
Old 02-24-2013, 07:05 AM
Full Force's Avatar
The 496 take off's are a perfect upgrade for older exhaust, they are aluminum center riser, and are 4" stainless risers... you can usually get them 250-500.00 per engine..
Full Force is offline
Old 02-24-2013, 11:13 AM
Good point on the TRS and prop setup. Thanks! The exhaust sounds very do-able too. l
deepv29 is offline
Old 02-24-2013, 05:27 PM
How does that center cushion in the cabin work? is that factory? would love to do that to mine. Could you send me some pictures of how it attaches and fills in?
Kaama302 is offline
