292 Fastech weight >
292 Fastech weight
292 Fastech weight
Old 03-04-2013 | 03:05 PM
Default 292 Fastech weight
Any chance someone has the weight of a 292 and triple axle trailer. Looking at a few, but want to make sure my truck is capable. Thanks for the help
CoffIslander is offline
Old 03-04-2013 | 03:13 PM
Fully loaded on the trailer you are looking at 10K lbs. give or take a few pounds.
08 fastech 292 is offline
Old 03-04-2013 | 05:57 PM
My 1500 GMC extended cab 4x4 handles my 292 fastech with dual axle eagle trailer with no issues. It also has the 4.8 engine.
oh6662b is offline
Old 03-04-2013 | 09:24 PM
I have a triple axle aluminum trailer and weighed in around 10k lbs when I moved from VA to MS.
diverkr is offline
Old 03-05-2013 | 07:50 PM
about 10k on tri axle ready to roll down the road.
LC
looseconnection is offline
Old 03-05-2013 | 08:06 PM
Expensive Date's Avatar
About 10k loaded, Not trying to start a OSO towing debate but I used to tow with a 1/2 ton Nissan Titan till I bought my dually. The Chevy will be a little better than the Nissan but you still will be at the trucks limits. Make sure your trailer brakes are working correctly.
Expensive Date is offline
Old 03-05-2013 | 08:39 PM
Wow, I am surprised they are 10k sitting on an aluminum trailer. I know they are wider than the 272's, but people say the 272 feels bigger in the cockpit. My 272 on a steel loadrite dual axle trailer I think came in a 8,000 lbs. Will have to check my records, but am pretty sure it was 8,000 lbs.
All the more impressive that these things weigh 2,000 lbs more, are pretty much the same length, yet run 6-8 mph faster for the same HP. Never would have guessed those numbers...
Brian
befu is offline
Old 03-05-2013 | 08:47 PM
Brian
Thats with 115 gallons of fuel.
Old 03-05-2013 | 10:17 PM
I don't tow on a regular basis, but I use a '99 Ram 1500. Longest tow was when I moved 800 some miles, but no issues with the triple axle and electric over hydraulic brakes.
diverkr is offline
Old 03-05-2013 | 10:50 PM
So minus 700 pounds for fuel, but not sure if my twin axle steel trailer that would fit a 30' boat weighs less than a triple axle aluminum. so about 1300 to 1500 pounds more than an old school 272 LS with Alpha's.
Anyway you slice it, that is quite a bit more glass and such. Impressive strength and speed increase given that info. Strong hull and no wood stringers to rot!
befu is offline
