Water in cabin floor compartment of 353 fastech??!! >
Old 10-01-2013 | 10:14 PM
Got water again! After deck wash, noticed step compartment was filling up. Looked a little closer, and water is draining from the joint between the deck and cabin door. With the brass drain plug installed the forward step compartment can't drain. Gonna try some silicone and see what happens.
bajamann is offline
Old 10-02-2013 | 06:39 PM
Did you check the thru hull fitting in the anchor locker? Mine broke and water made its way back under the step.
JTeam is offline
Old 10-03-2013 | 12:17 AM
yes. Anchor locker drain is sealed, drains fine.
bajamann is offline
Old 10-21-2013 | 08:58 PM
Havnt read any of the replies to this yet but for what it's worth the outlet hose came off our AC in the bilge under the step in the cabin and the bilge pump couldn't quite keep up so it would puddle up a bit. Finally found what was leaking and corrected it
PremierPOWER is offline
Old 10-21-2013 | 09:05 PM
