Help with Amp choice for new stereo!
So when it comes to engine work and mechanics Im pretty good..when it comes to choosing and hooking up the right stereo components..well lets just say I could use some help!
Here is what I have purchased so far
Sony CDX-M60UI head unit with a wired remote
Features:
Sony CDX-M60UI In-dash Marine AM/FM, CD, MP3, WMA player with Remote
iPod and iPhone interface built in through standard iPod to USB cable
Charge, control, and play your iPod and iPhone through the receiver
Detachable face
Dot-matrix display
Switchable blue and red button illumination
CEA-2006 compliant amplifier
Peak: 52 watts x 4 channels
RMS: 17 watts x 4 channels
MP3 ID3 Tag Displays Title/Artist/Album names
Plays CD, CD-R, CD-RW, MP3, WMA, and AAC
Radio tuner with 18FM/12AM presets
Dynamic Soundstage Organizer 2 gives you great sound staging for amazing sound quality
Built in 3-band parametric equalizer with preset tone curves and a custom EQ curve
3 Sets of 2V preamp outputs (front, rear and subwoofer)
SIRIUS or XM Satellite Radio Ready - Requires tuner, antenna, and subscription
HD Radio Ready: Sony - Requires Sony XT-100HD
Front auxiliary input
Rear USB input
Includes wireless remote
Quick-Browzer feature makes it easy to search for a track
Restores sound quality in compressed music files such as MP3 and WMA tracks
Wired Marine Remote Control Ready - Requires Sony RM-X11M or Sony RM-X55M
CD Changer controls
UV Resistant Paint
Amazing Sound Staging to make your speakers sound at their best
Clock
45 degree install Option
Loudness Control
CD Text
Tel/Nav Attenuation
4 Kicker KM6200 (11KM6200)
SPECS:
6" 2-Way KM Series Marine Speakers
Power Handling:
Peak: 390 watts per pair / 195 watts each
RMS: 130 watts per pair / 65 watts each
Injection-molded cones
Santoprene surround
3/4" Tweeter
Classic grille for a classic marine look
4 ohms impedance
UV Treated to withstand the harsh marine weather conditions
Frequency Response: 35-21,000 Hz
Top-mount depth: 2-7/8/16"
here is my question..I do want to add at least one sub in the cockpit to this later (possibly now just to get it all done at once) but not sure if a 4 channel will work for what I want and looking at pic of head unit there are only RCA outputs for front and rear speakers..
I did plan on hooking up all 4 cockpit to rear channel and 2 cabin speakers up to forward channel so I can isolate at night when I want to listen to music or watch a movie without disturbing neighbors..is that possible..if not I can live without that option! Here are the two amps I am considering!
KICKER ZXM350.4 MARINE AMPLIFIER 350 WATTS RMS 4 CHANNEL BRIDGED STABLE POWER
Specifications:
Kicker ZXM350.4 4-Channel Boat Marine Audio Amplifier 350 Watts (10ZXM350.4)
RMS Power Rating:
2 Ohms: 90 Watts x 4 Channels
4 Ohms: 60 Watts x 4 Channels
4 Ohms Bridged: 175 Watts x 2 Channel
PEAK Power Handling:
2 Ohms: 180 Watts x 4 Channels
4 Ohms: 120 Watts x 4 Channels
4 Ohms Bridged: 350 Watts x 2 Channel
ZXRC Remote Bass Control Included: No
ZXRC Remote Bass Control Capable: No
Dimensions: Height 2-1/8" x Width 9-5/8" x Length 13-1/2"
Frequency Response: 20Hz-20kHz
Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Selectable Electronic Crossover: Variable HI, LO, or OFF (bypass) 50200Hz, 12dB/octave
KICKEQ Boost: Variable 0 to 18dB @ 40Hz
OR
KICKER AUDIO 2010 ZXM700.5 R 5-CHANNEL MARINE & BOAT AMPLIFIER ZXM POWER AMP
Specifications:
4-CHANNEL RMS Power Rating:
2 Ohms: 85 Watts x 4 Channels
4 Ohms: 70 Watts x 4 Channels
4 Ohms Bridged: 165 Watts x 2 Channel
MONO RMS Power Handling:
2 Ohms: 420 Watts x 1 Channels
4 Ohms: 210 Watts x 1 Channels
ZXRC Remote Bass Control Capable: Yes
Dimensions: Height 2-1/8" x Width 9-5/8" x Length 20"
Frequency Response: 25Hz-20kHz
Subsonic Filter: 24dB/octave, fixed at 25Hz
Sorry for the long boring message but I wanted to include as much info for those that know to hopefully help me out..any help would be appreciated greatly!
Features:
Detachable face
Dot-matrix display
Rear USB input
CD Changer controls
UV Resistant Paint
Clock
Loudness Control
CD Text
Tel/Nav Attenuation
SPECS:
Power Handling:
Santoprene surround
3/4" Tweeter
4 ohms impedance
Specifications:
RMS Power Rating:
OR
Specifications:
It may have changed as I havent messed with audio in a few years, but a 5 channel amp was always a compromise. i was allways better to run a seperate amb for the bottom end and tune with a good active crossover. How you mount/enclose your speakers also make a HUGE difference. I had a ford ranger in my younger days, had 2 sets of component mids/tweets on a 4 channel, 2 8's on their own amp for mid base and 2 12,s own their own amp for the bottom.... It sounded ok but got a little muddy at volume. Took the time to build enclosures for everything to exact spec, sealed them good etc. Next problem was buying a new window for the back of the cab as I blew it completely out of the rubber gasket and the sound was worlds better,
I'm hooking up my cabin speakers to an amp hooked to the front outputs, and the cockpit speakers to an amp hooked up to the rear outputs. I figure I can just use the fader control on the head unit to kill the music in one area or the other.
I was also thinking about putting in subwoofers later, but bit the bullet and bought a couple JL 10's for under my back seat (building boxes in the seat compartment) and a JL 500/1 to run them. I figure if I am going to have to crawl all around the boat running wiring, I am only going to do it once. I would also highly recommend getting a dedicated amp to run your sub(s).
DYVMASTER-That head unit is what I have decided on myself , as it has 3 sets of 2.5v outputs-front,rear and a dedicated sub output,not just 2. Plenty of flexibility there. I myself will be running 1 4 channel amp off the front and rear outputs for my componets, and then utilise the sub output for a 2 channel amp pushing 2 10" subs. After looking at the options , I think the Sony CDX-M60UI is a good unit for the $$$, it offers a lot of flexibility and desirable features.. As stated before, the 5 channel amps are ok for ease of/cleaner installation, but a dedicated sub amp will push out more/cleaner sounding power.
I have a M1200 mono Rockford amp powering 2 10" Rockford subs and a Rockford M600 2 channel powering 2 Rockford M282's and 2 Rockford M262's. It must be good because my lady keeps telling me to turn it down it's vibrating the seats!!! Lmao
Have fun with it !!!
Thanks for the help guys..and Masonbig1..I looked over the Specs I posted and I suppose if I would have read them more thoroughly I would have seen that..Time will be the factor for me as far as if the subs get put in this time or not..I am out at sea now and gathering parts but I will only have 4-5 days to buff..wax..clean prep install new toys plus shakedown the ol girl after a winter port engine rebuild to make sure I can trust her to make a run to PIB..plus I have some ideas for custom installation of my subs that will take time..dont want to just throw and go..I agree though..would like to do it all at once but time isnt on my side! Its good to know the front and rear put out the same signal (thanks mike_mds) and that there is a seperate out for the sub as well..for this leave I think Ill get the 4 channel and hook up what I have and plan my install of subs..gather those parts and have the custom plates I have in mind cut and install next leave..as long as I can rock while Im running and sitting at the dock with a cold one Ill be pacified for now! Thanks again for the input
Formulas spot according to wiring diagrams is in the cubby above the fridge..I planned on putting the 4 channel there as well as the sub if there is room to mount..is there a benefit to having amp closer to sub?
