-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Old formula switches (https://www.offshoreonly.com/forums/formula/295285-old-formula-switches.html)
srdrago 04-26-2013 12:42 PM
Hello,
Does anyone know where I can get the old formula switches to match my 1985 242? Anyone parting out and have one or is there a site??
alj 05-01-2013 10:50 AM
may have some of these switches. can you post a picture? I have some from my F402 update.
srdrago 05-01-2013 01:27 PM
PM picture sent.
befu 05-01-2013 02:07 PM
for posting pictures, go to this thread. Page 7, post 66 explains how to use photobucket to post pictures. Really easy actually.
Switches, not sure what you have. Do they look like this?
http://www.ebay.com/itm/151011171595...84.m1497.l2649
This one fit the cutouts perfectly on my 86 - 272 dash.
Brian
Mr Maine 05-01-2013 02:38 PM
If its the rocker type shown on the ebay site above they are readily available, I even went to my local hardware store with about 10 feet aisle space worth of marine stuff and they had one, I had one blank on my panel and it snapped right in. Just not as faded as the other ones.
srdrago 05-01-2013 03:57 PM
I think the Ebay are not the actual ones, but close enough for what I want to do.
Dont mind the dirt/pollen:
https://fbcdn-sphotos-a-a.akamaihd.n...78631006_n.jpg
Level III Chaos 05-01-2013 08:14 PM
Is that pollen or MOLD?
srdrago 05-01-2013 09:03 PM
Ill look more when I get in there again, Its still all wrapped up.
Mr Maine 05-02-2013 06:07 AM
Those are the same as mine ('86). The one I picked up at the store didn't have an indicator light.
srdrago 05-02-2013 08:56 AM
Do you mean the Ebay ones you listed? I dont care much about the indicator light, but more looks. Rather have it look the same so that everything looks stock.
Mr Maine 05-02-2013 09:25 AM
I didn't post the ebay link. I just meant to say they are very universal and even though they are old design most marine stores should have them right on the shelve. Perfect match except for the fading on the old ones. Here is a link to one for 2.25$
http://www.sherco-auto.com/Merchant2...ry_Code=SWITCH
alj 05-02-2013 10:03 AM
Those are the same as my F402. I'll check to see what I have. I believe they are a gloss black not the matte grained black in the other posts. Are you looking for Illuminated or non? What accessory do they operate? Some are two position, some are momentary, etc.
srdrago 05-02-2013 11:10 AM
ALJ, you are 100% correct, they are gloss black. I need 4, doesnt matter if they illuminate or not. 2 are going to be for my docking lights (replacing the pull switch) and 2 will be for my new captain call exhaust. 4 or 2 will be great.
alj 05-02-2013 05:19 PM
I'll check in the shop attic to see what I have. I will tell you that any standard dash switch like these will not work with the docking lights unless you install some type of high amperage relay system. Those pull switches are designed for extremely high amperage loads like the docking lights. Be careful here as this can cause a wiring fire!
srdrago 05-03-2013 01:34 PM
Thank you for the heads up. Any chance you know what size relay would be good for those lights? So if I use the switch I can put the relay. Or if I purchase a new pull switch, what size I need.
alj 05-07-2013 11:13 AM
Drago,
I sent you an email about the switches, As I looked again at your pictures. I realized I only gave you part numbers for non-illuminated switches. If you look at the chart, you can figure out the designation for the illuminated switches I think. If not on that chart, I'll find it. The heavy duty switches I described in my email "may" work for the docking lights. If you stay with the standard metal push-pull switch, they are made by Cole-Hersey and are similar to #M482 or M682. You can find these online or at West Marine. The Formula wiring diagrams show 10 guage wire for the docking lights. That usually indicates at least 20 or 25 amps. You need a big switch for that kind of amperage. If you decide to "relay" the docking lights I would use a 25 amp to be safe. Hope this helps.
ALJ
srdrago 05-07-2013 06:19 PM
ALJ
Received your email. Very much appreciate it. I am going to look into it. Right now my captain call wont fit my Alpha drive, so I gotta figure out what I am going to do. but I may replace some switches/docking lights. Thank you so much for that information!
