-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Exhaust hose problem (https://www.offshoreonly.com/forums/formula/296097-exhaust-hose-problem.html)
Rossman40 05-09-2013 03:33 PM
454 330 horse with aftermarket Hardin exhaust. One side needed a new rubber exhaust sleeve due to a small burn hole directly behind the header. I replaced it and within an hour of run time it was back again. Water flow seems good and water wasn't very hot that was dripping from it. Header itself was warm but cool enough to touch. Any ideas?? I'm lost and want to get on the water badly!!
jwurl 05-10-2013 09:23 PM
If the hose is bent from manifolds and tips lining up , the hose will burn through. It needs to be a straight shot or you will have problems. Most Formulas have silent thunder boxes and Formula puts their tips in a slightly different spot for the muffler box. Jeff Wurl
Rossman40 05-11-2013 06:52 PM
It does have a slight angle, but that wouldn't examine why the rest of them are working fine, and only one is burning out. Could it be a blockage of water going out?
TWIN-SPINS 05-11-2013 08:07 PM
you must not have enought water flowing during high rpm runs,,,i would backflush,or look for a restriction
Rossman40 05-11-2013 08:07 PM
Explain... Sorry for the typo
TWIN-SPINS 05-12-2013 06:36 AM
http://www.offshoreonly.com/forums/g...er-flow-2.html
TWIN-SPINS 05-12-2013 06:51 AM
Originally Posted by TWIN-SPINS (Post 3923688)
another problem could be ,some of the old rubber pieces from the seapump impeller is blocking water flow,,,my guess is that you have enought water flow at idle ,,but not at high speeds,,,look for post about water seapump impeller replacement,,and backflushing ,,hope this helps
Full Force 05-13-2013 05:41 AM
Agree!
Biggus 05-13-2013 05:51 AM
I've had this problem years ago with a pair of Gil exhaust. Can you post a pic of the riser?
