formula 311 sr1 rpm
hey guys..i purchased a 1988 311 recently..the props i believe are prob stock..23p bravo..i have the 365 hp which are around 400hp a piece with the little work that have done to them..on gps i hit 68mph at 5200 rpm...is that to high of an rpm for these motors? should i go higher in pitch? the boat planes out awesome and cruises really well also...any input would be great..thanks!!
I had a 1990 292 sR1 with 365's and I had both 23" pitch and 25" pitch props. I went up to 25" pitch and had the same speed at a little lower RPM, $1,000.00 down the drain. If you don't have aftermarket exhaust, I would save the $1,200.00 and put towards stainless marine exhaust or some other aftermarket system. Also, the 25's will probably hurt your hole shot a little.
Something doesn't seem right. Bravo 23 (really 22) props @ 5200 rpms with a top speed of 68 equals 6% slip, which is not possible. A slip number of 11-13% would be more realistic which would give you a top speed of 64 mph. What have you done to you engines over stock?
Well, they don't make odd numbered Bravo props so he likely has 24's and that gets the numbers a little closer. If you are turning 5200 light then you are almost perfect, put people, a cooler, and fuel in and that will drop down to 4900-5000,
guy i bought it from said diff pistons and cam in motors..said each motor was 400 hp..i lied about props they're quicksilver not bravo and def 23p..i had a half tank of gas 5 adults 3 kidsand against the currant on river rpm gauge on boat said 5200 and gps said 67.9...gonna stay withwhats on it..seems pretty dialed in on taking off cruising and topend
