Tachometers not working properly >
Old 05-27-2013 | 06:02 PM
Default Tachometers not working properly
1998 Sunsport 280 ss with twin 5.7. The port tach doesn't work until I hit around 1000 rpm's then it would work pretty accurate along with starboard side gauge. Problem is now starboard side is starting to flutter around a bit. Especially towards the high end. What would be a contributing factor that would cause both? Could both gauges be going or probably a loose ground wire?
Here is a short video
http://i173.photobucket.com/albums/w78/neohiofan/90B90A04-898F-4041-88CC-AE23D015F398-13369-00000326672F86A4.mp4
neohiofan is offline
Old 05-28-2013 | 06:53 AM
I would check all the wires and make sure it's grounded properly, if it's still not working you might need a new one, it's like any other electrical device, they don't last forever, when mine started acting silly I bought two new one's from Livorse and said the heck with it, good luck.
314joey is offline
Old 05-28-2013 | 07:28 AM
I have twins and just wondering what are chances of both going bad at same time?
Old 05-28-2013 | 09:54 AM
Here's the other thing you can do, I've sent one of mine in and they'll check it for you for like $10 or almost nothing and if it's repairable they can fix it for lots cheaper than buying a new one, I did it once a few boats ago, worked great, the only thing is you won't be able to use your boat or if you do it won't have one of it's tachs, I had twins to and I just sent mine in and taped up the wires until it was shipped back to me, call them they can help you trouble shoot it.
314joey is offline
Old 05-28-2013 | 04:00 PM
Who did you send it in to?
Old 05-30-2013 | 09:16 PM
gaffrig or livorsi will do it
welfare racing is offline
