A little advice on this Formula purchase. >
Old 05-31-2013 | 01:33 PM
Originally Posted by zgoo
I like to drift down river and listen to music and enjoy a cold one?
That's what i enjoy doing, and mine is just a 272 SR-1, it's not that bad with 3-4 hanging on the boat, but any more than that we go to the Sandbar
Funnone is offline
Old 05-31-2013 | 10:54 PM
Yes, but the deposit can be refunded after full inspection, but thanks for the thought on it. I'm just used to older Nordic single engine 26' and this is a jump for me. On a different point, the cockpits are small for the length, how do you guys like that for relaxing on the water? I like to drift down river and listen to music and enjoy a cold one?
This style Formula compromised quite a bit in the cockpit room...thats why most family buyers will shy away from these types of boats. Dow here it's Center Console outboards 2 to 1 over all others for that reason....you can have a bunch of folks ridding along in a CC boat as opposed to a sport boat.
sprink58 is offline
Old 06-02-2013 | 08:32 AM
Well the boat has a true 155 hour on it. The cabin interior still looks new, A few things need attention, When it is plug into shore power, nothing happens, anybody know who to operate it?
zgoo is offline
Old 06-02-2013 | 09:05 AM
I have the same boat and I've been very happy with it. As to the charger, make sure the breaker in the cabin is switched to on. Also make sure the fuse is good in the charger itself. It's located in the lower left hand side of the charger, this is assuming its a Guest charger.
Also make sure the fuel is pumped as mentioned. My 292 was a similar buy, as in it sat for 8 years prior to me buying it. I had a hell of a time with the old fuel. I pumped it all out but that didn't resolve the issues. The old fuel created a pebble like residue that clogged my filters for an entire summer. I ended creating a fuel safe vacuum to suck the sediment out. Then as soon as I would get out in Lake Michigan and hit some waves, more sediment, clogged filters, more problems which meant draining the tank again and sucking out the sediment again. So that 10 year old gas could be a real pain, it may not be as simple as pumping it out.
With all that said, I really like my 292. For an older boat it still has great lines, it rides well, and is built well. I would also expect that you should be right around 70 MPH with a pair of 502's.
endeavour32 is offline
Old 06-02-2013 | 02:13 PM
I had 780 hours on my 1993 271 with very little compression loss. It all depends on how well they are maintained and how hard they were run. I agree with Sprink. Sitting unused for 10 years COULD be worse than normal wear and tear depending on how the motors were layed up prior to storage. Spend money for a thorough survey before spending your hard earned cash on this one.
Dave
08 fastech 292 is offline
Old 06-03-2013 | 06:38 AM
I had a 1990 292 SR1 with 365 hp magnums. Great solid boat. With the 502's you should see 70-75 mph which is fast for those older sr1's. Two things I would invest in right away. 1) Remove the stock exhaust and put in stainless marine or other aftermarket aluminum manifold and stainless risers with full stainless pipes back to the transom. You don't want the water to mix with the exhaust until it hits the transom area. This will prevent water reversion which will kill an engine over time. Also, initially inspect the seal between the cast iron manifold and riser. If there are rust staines on the outside, then you can be assured water is leaking on the inside into your heads. 2) Installl full hydraulic external steering and tie bar. At 70+ MPH, you don't want to rely on the stock mercruiser steering. After about a year or two of ownership, my boat would wander at speed in quartering seas, thought it was the boat's hull. Turns out the steering arm in the drives loosen up and causes the boat to wander. With the boat out of the water, shake the drives back and forth, if there is any play you either need to replace the steering arms in the drives or install the hydrualic steering. Other than those issue, I put over 700 hours on mine and it was a great boat. Good Luck.
38fountainecman is offline
Old 06-03-2013 | 10:47 AM
Thanks that is great advice! I put the aluminum ones on my last boat. I think I figure out way the charge would not work, there has to be about 10 amps in the batteries before the charger will turn on.
zgoo is offline
Old 06-03-2013 | 06:26 PM
I have a few more questions, I going to tun the engines over with the plugs removed and marvel oil in the cylinders to get oil pressure, then put on the muffs and try starting with a separate gas tank. What is the large hose with a gate valve on it that goes out the bottom of the boat and when and how do i use it?
zgoo is offline
Old 06-06-2013 | 08:38 AM
Wow what a day! So due to everybody's help here I backed out on this purchase. The Port motor ran great on the hose but the other had a slight miss, which could be a wire or plug. The big problem was the out drives. I know a top outdrive guy that has even published a book on outdrive repair fraud, so he inspects the drives and finds the one has a .125 bend in the prop shaft!! Plus there is gear whine in the lower unit. He said that the damage could go all the way to the motor and he has seen damage like this could require a motor removal! After changing plugs on theses motors, I not sure how you guys work on these engine compartments. The thought of changing a starter, I don't even want to go there! Sure like the look of that boat and will look for another. Also do you guys every rotate your drives?
zgoo is offline
