223ss Bimini top hardware size? >
Old 07-24-2013 | 12:12 PM
Default 223ss Bimini top hardware size?
I broke off a tab on the bracket that holds the Bimini top arms together. I forgot to bring the piece home and don't have access to the boat right now. can anyone tell me the diameter size I need to order? I need the outside eye end is it 7/8"?
bacon1 is offline
Old 07-24-2013 | 06:26 PM
If you're asking about the pipe diameter? Usually Bimini tops are made with 7/8" pipe. If it's the same size as the grab rail around your sundeck that should be 7/8" pipe. I had mine made with the same diameter pipe as the bow rail and I believe that is 1" on my 84 272
I'm not sure if I helped or not?
84 Formula 272 is offline
Old 07-25-2013 | 03:06 PM
It appears to be 7/8, I ordered parts and will report back if they don't fit. Thanks.
bacon1 is offline
