Remove windshield on a 353 >
Old 08-15-2013 | 12:05 PM
Default Remove windshield on a 353
Hi, Is it possible to remove the windshield on a 353 in a simple manner?
I need to get her into the lower parts of the garage..
skidolof is offline
Old 08-15-2013 | 03:06 PM
not a easy task,
88242LS is offline
Old 08-15-2013 | 04:06 PM
J.B. Marshall's Avatar
JB Marshall
Building a bigger garage will be easier
J.B. Marshall is offline
Old 08-15-2013 | 04:20 PM
Sydwayz's Avatar
Forum Regulator
Drop the tongue on the trailer down to the ground & and push it into place and/or let some air out of the tires.
Sydwayz is offline
Old 08-16-2013 | 02:26 AM
Ok, I hear you! Its just a couple of inches to high when I measured a little bit more accurate yesterday. I think dropped tounge and low air pressure will do the trick!
skidolof is offline
Old 08-16-2013 | 11:20 AM
My 312 didn't clear my Pole Barn/ shop so I was able to raise the header 5", Trim it out with white siding, bought one section of a garage door panel cut it down and put it at the top so not really visible. All good.. Took two days. Cost was about $250.00 material but now I just back her on in and give her a hug goodnight.
All I can say,, is the motto "DO IT RIGHT THE FIRST TIME: you'll be thank-full in the long run.
silent lucidity is offline
