353 Speed Question >
353 Speed Question
353 Speed Question
Old 08-27-2013 | 11:11 PM
Thanks for the feedback boys. Maybe I have been over trimming out, let me experiment again and I'll report back.
BoeingPilot is offline
Old 08-28-2013 | 04:59 AM
Full Force's Avatar
if you were trimming too far out you would have more rpm, or blowing props out making way more rpm...
Full Force is offline
Old 08-28-2013 | 06:26 AM
t500hps's Avatar
21 and 42 footers
That combo will rarely hit 70 but should be close (over 65 all the time). You should also spin about 5,000-5,100 rpms. Seems like 28's might be too big for the boat???? Are they 1.5 or 1.65 drives?
t500hps is offline
Old 08-28-2013 | 10:21 AM
I think I may have been trimming out too far, let me take another run on her and share the findings.
Old 08-28-2013 | 11:40 AM
i dont think it's your trimming. With my drives all the way in I would still go over 50mph... What RPM were you at? I had a similar issue this summer where the port motor wouldnt want to rev.. I changed fuel filter and was good to go.
FANTAZ28 is offline
Old 08-28-2013 | 12:46 PM
Does the boat feel sluggish? Does it sound as if the engine is straining? I would think running WOT and doing 50 the boat just wouldn't feel or sound right. Plus what's it doing out the back? Do you have a lot of spray? Is it calm and flat? Does the boat feel like the bow wants dip into the waves?
Splitdecision271 is offline
Old 08-28-2013 | 10:11 PM
I believe they are 1.5's
Old 08-30-2013 | 06:41 AM
I'll go along with that. 26 Bravo 1s will wake it up.
Again what RPMs at WOT??
Rattlesnake Jake is offline
Old 08-30-2013 | 09:30 PM
Update.
Took an ocean stroll to Palm Beach tonight. Mid to 3/4 throttle position, trimmed out to 5 max RPM is 4k and 47MPH.
Advance to full WOT and RPM is 4100 max 51MPH max estimated.
The fuel filters on the motors are new, and I've located an red anodized tubular Flow EZY in-line filter on both fuel supply lines made in Ann Arbor MI that I can not verify when they where new/serviced/changed.
Conditions: 1'ers, just myself, full fuel, full water, GPS based speed.
Whatcha boys think, in-line filters the culprit? Bypass them or replace? Are two fuel filters per motor necessary? Had computer on each motor last week to diagnose a needed relay replacement, code cleared and no other codes found.
Old 08-30-2013 | 10:05 PM
Start with checking compression and replacing spark plugs, leak down test would even be better...check fuel pressure as well...My guess burnt valves or fouled spark plugs
offshore junky is offline
