23p prop on a 242 >
23p prop on a 242
23p prop on a 242
Old 10-17-2013 | 01:17 PM
Don't waste your time with the Hydromotive quad iv in any pitch. Mine came with one. 5 minutes after leaving the dock i had to go back to put the 23p mirage plus back on. It spun right up but did't lift the bow at all. Topped out around 30-40 mph. I get 63 mph on the gps with the 23p mirage plus. Power is a stock carbed 502.
Fischan is offline
Old 10-18-2013 | 09:08 AM
moparjet's Avatar
my 89 242ls run a best of 65.5 on gps with a 502 cid with mild cam. EMI thunder manifolds. 23 mirage plus
moparjet is offline
Old 10-18-2013 | 07:58 PM
I think you'll find the 21p mirage + will work the best. That seems to be the consensus for a stock 242. I have a 233 with 454 mag / bravo 1 and run the 21p + @ 56/57 and 4800-5000 rpm. I have never tried the non + mirage, so I'm not much help there.
Deanrw3 is offline
Old 10-19-2013 | 04:05 PM
My bad, had GPS on Knots . Today I was hit in a high of 59 mph at 5100 rpm.mostly wanted to only get to about 57 ish. Mirage 21plus. 454 with 400 hp.
Originally Posted by KMONEY306
Def something wrong there. Sounds like you're getting too much rpm and way too little speed. Are you trimming it out etc. Is that speed GPS or the speedo?
shekmark is offline
Old 10-19-2013 | 08:43 PM
I am running a 23P thunderbolt at 4800 on my 88 242LS with a stock 454 mag.
Mohawk242 is offline
