93 - 96 Formula 252BR top Speed >
Old 10-09-2013 | 08:17 AM
Default 93 - 96 Formula 252BR top Speed
A friend of mine is looking into a 252BR and was wondering what type of top speed to expect with a big block with either outdrive bravo 1 or bravo 3. These motors should tach around 4,600 and 5,000 RPM correct? Stock prop 23p mirage?
slugoslugo272 is offline
Old 10-12-2013 | 08:06 AM
We had a 96 252LS with a 330 hp 7.4. It had a Bravo 3 outdrive. The best speed was 58 MPH GPS
Slow312 is offline
Old 10-13-2013 | 10:01 PM
My 97 252 LS with 502 MPI B1 23" Mirage is right around 62-63 on the top end. WOT RPM is with that set up is right at 5k.
TESTER 252 LS is offline
Old 10-14-2013 | 12:43 PM
Thanks for the info, test drove one that would only do 47mph and the tach was at 5,500 must of had the wrong prop on it.....
