Silent thunder gasket
Boating season is over here In Ohio so I'm fixing a few issues. I noticed the gasket was not sealing and there was exhaust blowing out between the transom and platform. If I remove the platform where can I get a new gasket for it? Also when reinstalling should I just use 5200 to seal up the bolt holes ?
Originally Posted by rcarroll
(Post 4021052)
I used 4200 on the thru hulls when reapplying the platform... I only use 5200 when I have no plans to EVER do the job again. FYI - You most likely will also see that your swim platform wall that sits against the transom is rotted... Mine was extremely rotted... So be prepared to have to rebuild the fiberglass up as well. |
you just need some ~3/4" D shaped Gasket stock .... Ditto on the 4200 .... Also on the rot ... m
http://www.mcmaster.com/#foam-rubber...askets/=p8gw16 http://www.speedwake.com/forums/showthread.php?t=58926 |
Good luck! If all else fails put through-hulls through the platform too.
(Post 4021052)
throw that junk in the dumpster!
The inner gasket surrounding the exhaust pipes are:
0064 EA GASKET D SHAPED CIRCLE 128P-A $13.20 each We also started using what we called "five-finger" gasket around the perimeter of the platform/transom interfaced: 4143 FT GASKET CS103 HR1 103H3-500 $1.00 per linear foot The five finger gasket has a peel-off backing, and you will need to hot glue the circular gaskets. |
2 Attachment(s)
Ok I took the platform off today it does not appear to be made of wood it's like a foam core wrapped in glass. May have been fixed once idk. Anyways I will contact Scott for the gaskets because I can't find a aluminum platform for under 1500 if mine was rotted or messed up I would prob spent the $$ [ATTACH=CONFIG]513364[/ATTACH][ATTACH=CONFIG]513365[/ATTACH]
And one other thing the flappers inside the hull tips are missing. Would it be a good idea to install some clamp on rubber flappers ???
The rubber flappers are easy to change now. Take a long screw driver and pull off rectangle tip top 2 screws. The flappers are pinched between the stainless strips along the top.
Easier to do now the ST deck is off. I've done 9 tip flappers with locally available rubber. Get the kind that has a cloth integrated into it. Little more durable. Or just go red or orange silicone to show off the tips. |
| All times are GMT -5. The time now is 05:24 PM. |
