Oil pressure issue
Well... I sent the gauge and sender out to Gaffrig and they both checked out. That being said I was told that the sending unit looks old, corroded and might have some stuff on the threads giving it a ground issue at higher RPM.
I just hope its nothing in the internal engine
Haider ... As I had told you, after I replaced the connectors on the Senders it seemed to correct the issue but now the Starboard Gauge has started the fluctuation issue while underway ...I swapped the senders and the problem stayed with the Starboard Gauge...So I guess the gauges can be the issue as well ....Are yours the original OP Gauges that have the Low OP Light? I dont think they make those any longer ......m
