Leaving in a few to drag home another bird >
Old 04-04-2014 | 11:09 AM
aquaforce's Avatar
Originally Posted by 88242LS
Belonged to Doczdoc here locally, very nice boat and very well maintained, lift kept, 2/3 owners since, but no one has kept it very long not sure why, last time I saw pics it still looked great
Well if the other 357 owners are like me this is a step in the direction of a 382. That is ultimately where I want to be but this works well for now; I'm on the water. Once the stars line up mine will be for sale too because I will be moving up to a 382.
aquaforce is offline
Old 04-04-2014 | 11:39 AM
That is what I did and the only reason I sold the 357....... I really like my 382, but still think the 357 is an awsome boat. Love the looks / lines of th eold SR1 boats.
jriggs is offline
Old 04-04-2014 | 12:42 PM
Originally Posted by jriggs
You are correct 242ls. I bought the boat back in 2009 from Greg (Doczdoc) and know the history of the boat very well dating back to 2004. Not sure on the battery issue, never had anbything like that going on when I owned it, hopefully it is just a bad battery. Glad to see the boat will be back on Lake Erie this summer.
We dug I to it last night, and there is no heavy ground wire from battery 1 to the ground bus. Hooking a jumper cable to the engine and she cranked over no problem
RT930turbo is offline
Old 04-04-2014 | 01:15 PM
Sounds like someone removed th batteries for winter storage and they didn't get put back in properly or something. I remember installing new batteries in the boat shortly before I sold it.
jriggs is offline
Old 04-04-2014 | 01:43 PM
I wish I had access to the boat right now, because the more I think about it the more I think the last monkey who changed the batteries might have missed the negative in a rush to head to the lake ..... I guess I get what I pay for at the service department at Clark's storage barn. Poor Artie is running around installing batteries for free and then taking the blame when it doesnt work out.
I also changed the stereo wiring a bit too. The head unit was hardwired to the right battery and the amp was hardwired to the left. I moved everything to the left so we can listen to the radio without using both banks. Looking forward to some more warmer weather so we can test her out again.
auto_werks 3.6 is offline
Old 04-04-2014 | 01:54 PM
Rigger, please.
Old 04-04-2014 | 02:06 PM
When I bought the boat it had three small amps installed under the sink. I purchased the MB Quartz amp and threw it in there using the existing wires. If memory serves, it had some pretty heavy duty wiring running up from the engine compartment (like #2 wire) and it ran to the battery on the port side. I can also tell you if you push the amp to hard it will overheat in like 20 minutes or so and cut out. So if you are at the dock and cranking the tunes you need to leave the door open and put a small fan on it or something.
Sounds like you better trailer over to an Autozone or something and have them check "Clark's Storage Barn's" work.
jriggs is offline
