I had the water under the step issue when I first purchased mine. It turned out that I had the nose to low when stored, I now jack the front end way up, no problems in 3 years. Start with this simple step first, there may be something else going on, but this is a good starting point. Oh, store with drain plug out.
Boat is currently stored all the way up on level ground. I also have started using my full cover instead of just the cockpit cover. Will report findings of water after tomorrow when I get to use it.
I believe one of the problems was leaking around the windshield if the weather stripping was bad.
Pictures "in motion" from our local poker run on the Tn River.
http://newpics.huntsvillecarscene.co...-C5H5VsN-M.jpg http://newpics.huntsvillecarscene.co...-xBCH6FF-M.jpg |
Very nice Formula, how does she run ??
| All times are GMT -5. The time now is 11:33 AM. |
