selling my 1986 242
I know this is an old thread but just curious what kind of speeds you got out of the boat with the big block. I have the same year boat I recently purchased with a worked over small block and was curious if going to a big block was worth it.
Looking back if I had to do it over again I would have used the boat for what it was and sold it when I wanted to go faster and gotten into something that had a bravo and big block to start.
My 242 came with a 330hp 454 previous owner said beat he got was 53mph. It had a 425hp 476 in it when I got it and I got 64 out of it. Now I have a 509 making around 600hp. I havent even dialed it all in with props but am running low 70s.
I have a 232ls. I bought it with a 350 mag. I have since put a 8.2 big block in it. There is a big difference in feel of acceleration. Never mind the low 50's with the 350/ to low to mid 60's with 8.2. Propped a little different. Remember Formulas are heavy. I think there is a big difference. Go BB
Remember the old rule of thumb. There is no replacement for displacement. A big block has more rotating mass. More inertia means more torque. Generally a 300hp big block will have much more tq than a 300hp small block. If you decide to go big block and bravo you will be looking at a lot of work. And even more money. Best to sell the boat and buy one set up the way you want if that's your desire.
That was my old boat. It started out as a small block with an alpha that ran in the low 40 mph range. Over one winter I built a worked vortec roller 350 with aluminum heads and a cam that pushed the boat into the low 50 mph range. I wanted more out of the boat so I removed the small block and alpha combo and upgraded to a bravo one and a 510ci BBC. The motor made 525hp with similar torque and with a 23 mirage plus prop ran in the lower 70s. I had a Livorsi gps speedo installed for all the different motor combos. When I went to sell the boat I removed the 510 and installed a Craigslist mercruiser 454 that made 420hp which pushed the boat into the Low 60’s.
