Help!!! 242ls wiring problem
Email me a picture. The only difference I've ever seen is in the small pins. And I've swapped motors around in close to 100 boats.
[email protected]
[email protected]
then maybe 1 pin broke off from a prev harness when pulled apart ,and its still in the engine side ...I will tell you they will plug into each other .I had an 88 formula 24 ss I did a while back ,,I put a 496 ho in ..never changed harness .plugged right in no adapters nothing
