Speaker Locations
So - I am doing a system in the boat here soon. I have a 33'6. My thoughts are amp and all will go in the closet in the cabin. All JL speakers and 2 subs. This is still tentative but I will do 2 subs and 2 speakers below the rear seats. and then 2 speakers, 1 by the captain and 1 passenger. I will also do 2 speakers in the cabin. Any other suggestions on where you all have put speakers? I wanted to put them on the side of the rear cock pit but i have storage there. I saw a guy that mounted his up higher by the back seats but not sure I want to mount the speakers up higher above the cup holders. Not sure if I am set on the look or not.
Send me pictures with what you have done pleaseee! |
Place the speakers as high as you can. The system will sound much better if you can get your mids/highs up high.
mount the speakers just like they sound like. bass down low. mids in the middle. and highs up high.
That's the problem. Subs aren't bad but there aren't many places to mount the speakers.
1 Attachment(s)
[ATTACH=CONFIG]534547[/ATTACH]
Blake, Maybe you can do something like what axa did with "chillin". Mount them up behind the seats. I am not familiar with the cockpit of your new boat so this is the best I can do to help my brother out. Good Luck !!! Chris |
http://www.ebay.com/itm/MARINE-UNIVE...item3a946c8195
I am putting this on the under side of the bolster firing back to the back seat, we always stand so the speaker will be directed towards the rear seat. I like the sound of 6x9's so i will have 4 in the cock pit powered by a 4 channel amp. I have the speakers in the cabin disconnected so my daughter can sleep and we can party. |
Chris - those pods are sweet but I am sure they were not cheap to make.
No go on the ebay link, the only speaker that will fit is a auto zone special with no magnet.
Originally Posted by badmonkey
(Post 4236517)
Blake, Maybe you can do something like what axa did with "chillin". Mount them up behind the seats. I am not familiar with the cockpit of your new boat so this is the best I can do to help my brother out. Good Luck !!! Chris . |
Not sure I would mount the amps in the closet due to lack of ventilation and heat build up. On my 311, I remounted amps on the inside wall of the side coaming ahead of the sliding lexan access panel.
Pictures of the interior would help.
For the best overall sound you want your speakers aimed in the general direction of the occupants, not low. The higher you place them, the 'fuller' they will sound. Bass is omni-directional, so you can usually mount subs lower without noticing their position. |
where did you get the enclosures for the speakers behind the front seats?
I interested as well putting a single sub under the rear seat for now and a new receiver.
I would like to see which subs you used. |
| All times are GMT -5. The time now is 12:19 PM. |
