-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   311 sr1 questions (https://www.offshoreonly.com/forums/formula/321498-311-sr1-questions.html)
Gh700xx 12-28-2014 05:55 PM
311 sr1 questions
Hey guys I have been looking at a deal that may go through on a solid 311 hull it's an 87 with no power etc but the price may be too good to pass. Who here has had one and are here any peculiarities or known issues i should look for or problem areas? Boat was complete till recently and like I said I'll be repowering it if I end up with it. Just checking to see how solid they were.
buckknekkid 12-28-2014 06:10 PM
I have all the trs parts to put it together quick
Gh700xx 12-28-2014 06:27 PM
Lol trying to decide if I want trs or if I want to track down everything and out kaamas on it. Any tips on anything to look for on this hull? Or they pretty solid?
buckknekkid 12-28-2014 06:44 PM
1 Attachment(s)
stringers, bulkheads and of course the transom. like all boats they are prone to aging and with out proper care they develop issues. The interiors need care, rigging gets scrambled over the years. I took everything out and put it back in again :party-smiley-004:
switchbackman 12-28-2014 08:09 PM
I just got one myself transoms where a problem not only where the drives are but also check the silent thunder swim platform if it has one . Stringers and bulkheads . Check under the cabin step it's hinged . Also from info I have found the gasket under the windshield goes bad and water can leak in where the screws but it doesn't show on the headliner. Good luck and keep us posted
Gh700xx 12-28-2014 08:17 PM
Cool deal I will check all those places. But thank god It don't have the thunder platform. Yay
switchbackman 12-28-2014 08:23 PM
Also formula liked to put foam under the cockpit floor to insulate the gas tank and the foam would hold water
Gh700xx 12-28-2014 08:36 PM
Ok I remember seeing something bout that in a thread on here.
switchbackman 12-28-2014 08:45 PM
But they are great boats they are heavy I think the 311 weigh in at 7800 lbs but a guy on here said with stock 454s she will do 60 and they where built for ruff water . Also you can contact formula directly there Tec support is second to none
Gh700xx 12-28-2014 09:22 PM
Cool deal thanks for all the info guys.
