What are the "rules" for impeller replacement ? >
Old 01-22-2015 | 07:21 PM
badmonkey's Avatar
Originally Posted by Splitdecision271
Best advice if you do it yourself just remove the entire pump don't try replacing just the impeller with the housing still in the boat. 2 hoses and a few bolts the whole housing comes out and you can work on it in plain sight and not hanging upside down in a very cramped area.
Well said Split.
badmonkey is offline
Old 01-23-2015 | 04:46 AM
As far as 'rules' . . . well perhaps a guideline . . . every 50 hours 'check' ,and 100 hours 'replace'. . . . for me that means check the impellers one year and replace them the next year.
If you have a sea water strainer in line before the sea water pumps, then it can extend the life of the impeller by about 2 X.
In my 242, I had to remove the sea water pump in order to have a decent job of replacing the impeller. In my 330, I can change the impellers without removing the pumps. All depend on the access. The 292 might be a bit tight, but should be OK.
tpenfield is offline
Old 01-23-2015 | 09:36 AM
Here is a nice video for a first timer. https://www.youtube.com/watch?v=UxLfF2abE_o
Donzi540 is offline
Old 01-23-2015 | 02:41 PM
Thanks everyone .... Looks like a good job to do after the first run in spring ....
Roody727 is offline
Old 01-23-2015 | 08:51 PM
ROB FREEMAN's Avatar
add a little dish soap for initial start up also .. good little tip
ROB FREEMAN is offline
Old 01-23-2015 | 08:54 PM
add a little dish soap for initial start up also .. good little tip mark youre hoses so you dont swap them around .orb youll be buying a whole assembly when she cracks from heat ,, lol dont over tourqe the bolts either .. good luck in dive in .. srry dint mean to duplicate shucks
Old 01-24-2015 | 05:54 AM
I love how PPT Videos show the engines and related parts in pristine condition, with easy access, and the bolts already loosened.
Kind of distorts the reality of it all . . .
