Prop advice on a 271 SR1 >
Old 02-10-2015 | 03:51 PM
Default Prop advice on a 271 SR1
Hi Guys
What is the best prop for a 271 SR1 with a 502 560 Hp (Dyno tested) Bravo 1 XR 1.50 ??
I would like a normal hole shot, good cruising speed and a hig top end he he ;-)
Monaco20 is offline
Old 02-10-2015 | 08:12 PM
25 mirage plus
Mr Maine is offline
Old 02-11-2015 | 05:34 PM
Thanks for the reply Mr Main :-)
I had actually a 4 blade propeller on my agenda, because of the all around performance ....
Why do you suggest a 3 blade ?, based on experience ?
BR
Rune
Monaco20 is offline
Old 02-11-2015 | 06:21 PM
What rpm are you shooting for? It is a straight bottom hull that needs bow lift and with a deep drive a 3 blade mirage would be fastest. A bravo 4 blade won't have the lift and you will lose some top end, but yes gain some midrange.
I have heard the Rev 4s give more bow lift than a bravo so that may be an option too. There is no one prop that is best for everything. If it was a 271 fastech with a step I would say bravo 4 blade.
Mr Maine is offline
