Stereo Install in my 330SS >
Old 04-26-2015 | 07:15 PM
VERY CLEAN!!
I love the install. Did you make the LED rings or buy them?
Jonesyfxr is offline
Old 04-27-2015 | 01:20 PM
I made them out of 1/2" acrylic... Pretty easy to do with a good plunge router and a circle jig.
alindquist is offline
Old 04-27-2015 | 06:03 PM
Where'd you get your RGB LED's?
Old 04-28-2015 | 07:01 AM
Amazon, like $15 for a 5 meter strip, I think I used 2 or 3...
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 04-28-2015 | 03:54 PM
Thanks. I saw Frisco Jay make his own too. I have the circle jig for my router. I might do the same. It really is sweet!
Old 04-29-2015 | 12:04 PM
Originally Posted by alindquist
Br1dgemann: My last boat had Polk Momo's and they last about 6-7 years before I finally blew them up, I replaced them with Wet Sounds 65i's and they are still working. As far at the cone goes they were still in good shape. Provided I don't blow these speakers I would think I should get 5-7 years. Hopefully at that point the boat will be sold and I'll be on to something bigger.
Aaron
I may have to try Wet Sounds. Thank you, Aaron, for the Info and Enjoy those Tunes!!
Br1dgemann is offline
Old 06-17-2017 | 05:52 AM
Default Tv mount
set up looks awesome. I just bought a 330 sand I think I'm going to do my stero the same except I have all Jl audio. Quick question how did you mount the tv? To where and what kind of bracket?
Eleanor is offline
Old 06-21-2017 | 06:42 AM
I just used a normal bracket that you would buy at Walmart or off Amazon. Once the TV was hung I ran a few zip screws in from the side to keep the TV from jumping off the mount...
Old 06-21-2017 | 07:56 AM
Does it mount right to the mirror? Is it thru bolted or lags? My boat never had one so I just want to do it the way it should be. Thanks
Eleanor is offline
Old 06-21-2017 | 06:25 PM
I drilled a few holes in the mirror and screwed it to the wall behind. I put some rubber bushings between the mount and the mirror... so far so good. I think I have literally turned that tv on 2-3 times since I installed it, but it looks cool.
